跳转到主内容
加入维修社区 - 创建账户
2 slice Dualit toaster Disassembly
  1. 2 slice Dualit toaster Disassembly, Removing rubber feet: 步骤 1 中的图像 1,1
    • 4 x rubber feet
    • 5 x metal screws
    • Remove the rubber feet and screws with a phillips head screw driver.
  2. 2 slice Dualit toaster Disassembly, Removing bottom plate: 步骤 2 中的图像 1,1
    • 1 x Matte Aluminium Bottom Plate
    • After removing the Feet and Screws the Bottom plate simply lifts off.
  3. 2 slice Dualit toaster Disassembly, Removing crumb tray: 步骤 3 中的图像 1,1
    • simply slide out the aluminium crumb tray
  4. 2 slice Dualit toaster Disassembly, Removing main polished casing: 步骤 4 中的图像 1,1
    • 1 x Stainless Steel main casing
    • 6 x Phillips Head Metal Screws
    • Remove screws from main body of toaster and ply the metal casing off with your hands from either side.
  5. 2 slice Dualit toaster Disassembly, Removing end cap: 步骤 5 中的图像 1,1
    • 1 x Casted Aluminium End Cap from the left hand side of the toaster
    • After removing the screws from part 4 this end cap will just pull off with a gentle tug.
  6. 2 slice Dualit toaster Disassembly: 步骤 6 中的图像 1,1
    • 1 x Cast Aluminium timer casing
    • To remove the other side casing of the toaster you must first disconnect the electrical cords from the elements
    • Once all the cords are unplugged the casing will simply pull off the same way as the other side casing was removed
  7. 2 slice Dualit toaster Disassembly: 步骤 7 中的图像 1,1
    • 2 x Nut
    • 2 x Bolt
    • 2 x Washers
    • 1 x Galvanised Steel elements fastener plate
    • To remove the element fastener plate us the pliers to prevent the nut from twisting whilst unscrewing the bolt with the PH screwdriver.
    • Once unscrewed the plate should easily pull away.
  8. 2 slice Dualit toaster Disassembly: 步骤 8 中的图像 1,1
    • 1 x Lever mechanism
    • 1 x Spring
    • 1 x Washer
    • 1 x Plastic lever handle
    • 2 x Aluminium fastening plates
    • To remove the Lever mechanism you must first unscrew and remove the black plastic handle.
    • After this the two fastening plate will can be removed. The screws holding these in place have already been removed in the previous step.
    • The lever mechanism can now be removed from the toaster. This may take some manoeuvring for the mechanism to slide out.
  9. 2 slice Dualit toaster Disassembly: 步骤 9 中的图像 1,1
    • 3 x heating elements
    • 2 x Brass dividers
    • 2 x Copper wires
    • 2 x Bolts
    • 6 x Washers
    • 4 x Nuts
    • To remove the heating elements unscrew the bolts with the PH screwdriver whilst holding the nuts with the pliers
    • Once unscrewed the wires and copper dividers are able to be removed. Then simple slide out the heating elements. The elements need to be replaced in the same slots they came from so label them.
  10. 2 slice Dualit toaster Disassembly: 步骤 10 中的图像 1,1
    • 2x aluminium internal side panels.
    • These thin aluminium plates will then be removed from the main body assembly. These sheets help reduce heat admitted from the toaster upon use.
  11. 2 slice Dualit toaster Disassembly: 步骤 11 中的图像 1,1
    • 3x bent stainless steel excursions.
    • These parts are holding the bread in a perfect position in relation to the elements. They are then to be popped out of place from the main body assembly.
  12. 2 slice Dualit toaster Disassembly: 步骤 12 中的图像 1,1
    • This is the final sub assemble or main body you are left with. This body is the queen bee of all the above parts.
结论
2等其他人完成本指南。
hugh johnston
于04/23/20注册
265 声望
撰写一个指南
7指南评论
What size are the screws used to secure the outer casing?
Roger Houghton - 回复
On my model A2BR/87 they’re #2 Pozidriv screws.
You can tell the difference between Phillips and Pozidriv screws because the latter have very small lines etched between the four arms of the cross on the screw head. Phillips screws (and screwdriver) should work, but if you use them too many times on a Pozidriv screw then they'll eventually wreck them. On the other hand, you can't use a Pozidriv screwdriver at all on a Phillips screw so check to see which kind of screw you have.
FWIW, I had to get Pozidriv screwdrivers to work on my Saeco espresso machine.
Colin Macdonald - 回复
If you just need to replace the Dualit 2 slice toaster, Lifter Assembly what is involved in doing that. Surely you don't have to remove all the sides etc. What would you recommend to replace this one element?
Charles Tremewen - 回复
unscrew the black round knob on the lifter and unfasten screws
ellamama -
Is the Cast Aluminum Timer Casing one part that is available? My toaster is an American Dualit. The timer mechanism doesn't work. I would like to replace just this part. Can you help me remove it?
Bernie H - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 45
过去 30 天: 244
总计 7,653
