跳转到主内容
加入维修社区 - 创建账户
1999 GMC Suburban Brake Light Replacement
你所需要的
    1. 1999 GMC Suburban Brake Light Replacement, Brake Light: 步骤 1 中的图像 1,3 1999 GMC Suburban Brake Light Replacement, Brake Light: 步骤 1 中的图像 2,3 1999 GMC Suburban Brake Light Replacement, Brake Light: 步骤 1 中的图像 3,3
      • Before you begin, turn off your car, put it in park, and engage the emergency brake.
      • Select the side of the car you would like to work on first.
      • Open the trunk doors.
      询问修复机器人
      添加评论
    2. 1999 GMC Suburban Brake Light Replacement: 步骤 2 中的图像 1,3 1999 GMC Suburban Brake Light Replacement: 步骤 2 中的图像 2,3 1999 GMC Suburban Brake Light Replacement: 步骤 2 中的图像 3,3
      • These two holes have screws inside of them, so unscrew them to get the brake light out.
      • The screws that will be removed for this step are "Round washer head pozi-drive tapping screw tail lamp assembly M4.2-1.41 x 20mm".
      询问修复机器人
      添加评论
    3. 1999 GMC Suburban Brake Light Replacement: 步骤 3 中的图像 1,3 1999 GMC Suburban Brake Light Replacement: 步骤 3 中的图像 2,3 1999 GMC Suburban Brake Light Replacement: 步骤 3 中的图像 3,3
      • When removing the tail light there are little hooks with holes that are used to hold them in place as shown in the first photo.
      • The tail should already be loose from the previous step so pull it out slowly by turning it on its side and then pulling forward.
      • Use the 7 mm socket to unscrew the two bolts securing the brake light housing to the tail light assembly.
      • The screws in this step are "Rexka 30pcs M4.2-1.41 x 20mm".
      询问修复机器人
      添加评论
    4. 1999 GMC Suburban Brake Light Replacement: 步骤 4 中的图像 1,2 1999 GMC Suburban Brake Light Replacement: 步骤 4 中的图像 2,2
      • After taking off the screws, take the brake lights out and find which light isn't working by stepping on the brake.
      询问修复机器人
      添加评论
    5. 1999 GMC Suburban Brake Light Replacement: 步骤 5 中的图像 1,1
      • With the actual light, unplug them by pulling them out but not with too much force.
      • Plug the new light bulb(s) in place of the ones that don't work.
      • Please be careful with how you remove the bulbs because they are made of glass.
      询问修复机器人
      添加评论
    6. 1999 GMC Suburban Brake Light Replacement: 步骤 6 中的图像 1,2 1999 GMC Suburban Brake Light Replacement: 步骤 6 中的图像 2,2
      • Now put everything back together and put all the screws back on.
      • The steps are the same on both sides and is a fairly simple and fast process.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Marcos Shipley
于10/25/23注册
154 声望
撰写一个指南
团队
CSU Los Angeles, Team 12-10, Ribeiro Fall 2023 CSU Los Angeles, Team 12-10, Ribeiro Fall 2023 的会员
CSULA-RIBEIRO-F23S12G10
1 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 34
总计 1,014
