简介
If your 1999 GMC Suburban’s brake lights aren’t working, you can utilize this guide to replace them. This guide will give step-by-step information on the process from start to finish. This is an overall easy and simple task that can be done in less than 15 minutes. Step 5 requires you to remove the bulb from the socket. The bulbs are made of glass, so handle them with care to avoid shattering them. Wearing nitrile gloves is recommended, but not completely necessary.
你所需要的
Select the side of the car you would like to work on first.
Open the trunk doors.
