跳转到主内容
1999 Ford Contour Sun Visor Replacement
你所需要的
  1. 1999 Ford Contour Sun Visor Replacement, Sun Visor: 步骤 1 中的图像 1,1
    • Unscrew the visor from its housing.
    • The screws used are 1 inch sheet metal screws with a Phillips head.
  2. 1999 Ford Contour Sun Visor Replacement: 步骤 2 中的图像 1,1
    • Disconnect any wires attached to the visor by squeezing the tab located on the power cable connector.
    • Reconnect the wiring before proceeding to the final step.
  3. 1999 Ford Contour Sun Visor Replacement: 步骤 3 中的图像 1,2 1999 Ford Contour Sun Visor Replacement: 步骤 3 中的图像 2,2
    • Completely remove the visor and replace with a new one.
结论
Once all steps are completed, the sun visor will work as before.
2等其他人完成本指南。
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 22
总计 2,283
