跳转到主内容
1999-2001 Mazda Miata (MX-5) Door Speaker Replacement
你所需要的
  1. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement, Door Speaker: 步骤 1 中的图像 1,2 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement, Door Speaker: 步骤 1 中的图像 2,2
    • The battery is in the right side of the rear cargo compartment. It can be found by moving the carpet and wood cover.
    • With a 10mm wrench, remove the positive battery terminal.
    • Do not let any metal in contact with the positive battery terminal contact any other metal item. This might make sparks.
  2. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 步骤 2 中的图像 1,3 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 步骤 2 中的图像 2,3 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 步骤 2 中的图像 3,3
    • Remove the three trim panel retainer clips.
    • Old clips might break easily. Be extra careful when removing them or get spares.
  3. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 步骤 3 中的图像 1,3 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 步骤 3 中的图像 2,3 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 步骤 3 中的图像 3,3
    • Remove the three screws that hold the door panel in place.
    • These screws are all different, so keep note of where they all go. The short screw goes in the door latch; the long screws go in the door handle.
  4. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 步骤 4 中的图像 1,2 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 步骤 4 中的图像 2,2
    • Remove the cover around the door latch by pulling the handle and rotating the cover.
  5. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 步骤 5 中的图像 1,2 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the door panel by pulling the bottom out and lifting up.
  6. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 步骤 6 中的图像 1,3 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 步骤 6 中的图像 2,3 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 步骤 6 中的图像 3,3
    • Remove the four screws holding the plastic speaker mount.
    • As you remove the screws, don't let the speaker fall out and pull the wire.
  7. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 步骤 7 中的图像 1,3 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 步骤 7 中的图像 2,3 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: 步骤 7 中的图像 3,3
    • Detach the connector that powers the speaker by pressing down on the top latch and gently pulling.
    • A small screwdriver might help with the latch but be careful. Old plastic can be brittle.
结论
Nathan J
于02/20/24注册
145 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 29
总计 134
