跳转到主内容
1999-2002 Suzuki SV650 Seat Replacement
你所需要的
  1. 1999-2002 Suzuki SV650 Seat Replacement, Seat: 步骤 1 中的图像 1,2 1999-2002 Suzuki SV650 Seat Replacement, Seat: 步骤 1 中的图像 2,2
    • If you have frame covers below your seat, remove them by removing the 4 mm allen bolts holding them on. Use a 4 mm allen wrench to turn the screws counter-clockwise until they come off.
    • Once the frame covers are off, remove the 4 mm allen seat bolts on both sides of the seat. Use the 4 mm allen wrench to turn the screws counter-clockwise until they come off.
    • The bolt in the picture is not stock.
    • Lift the front of the seat, then pull it off the frame.
结论
另外一个人完成了本指南。
Phillip Takahashi
于08/22/11注册
86,704 声望
创作了87篇指南
一条评论
seat bolts are actually 6mm Allen (side covers are 4mm Allen).
thineownself - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 54
总计 7,882
