跳转到主内容
1999-2004 Volkswagen Golf Front Windshield Wipers Replacement
你所需要的
  1. 1999-2004 Volkswagen Golf Front Windshield Wipers Replacement, Front Windshield Wipers: 步骤 1 中的图像 1,1
    • Use a flathead screwdriver to remove the cap from the windshield wiper.
  2. 1999-2004 Volkswagen Golf Front Windshield Wipers Replacement: 步骤 2 中的图像 1,1
    • Use a socket wrench to release the passenger-side windshield wiper locking nut.
  3. 1999-2004 Volkswagen Golf Front Windshield Wipers Replacement: 步骤 3 中的图像 1,2 1999-2004 Volkswagen Golf Front Windshield Wipers Replacement: 步骤 3 中的图像 2,2
    • Gently lift up the passenger-side windshield wiper.
  4. 1999-2004 Volkswagen Golf Front Windshield Wipers Replacement: 步骤 4 中的图像 1,1
    • Remove the driver-side windshield wiper in the same fashion.
    My windshield wipers were stuck on like they were welded. I removed them with channel lock pliers. I put the top jaw of the pliers and placed it under the wiper and the bottom claw of the pliers and put it on the mounting bolt. squeezed as hard as I could and Pop! It came loose.
    Nils Stansen - 回复
结论
4等其他人完成本指南。
Matthew Newsom
于01/05/10注册
39,500 声望
创作了67篇指南
一条评论
one has to be careful with the rain tray. if you use too much pressure whil trying to get the wipers off, you will damage (crack) it.
there is a special tool for getting them off; this is a bit pricey.
elchmartin - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 13,770
