跳转到主内容
修复你的物品
维修的权力
商店
简介
This repair guide shows you how to replace your Golf's plastic rain tray.
配件
没有特定配件。
  1. Use a #2 Phillips screwdriver to remove the four screws.
    • Use a #2 Phillips screwdriver to remove the four screws.
  2. Remove the rubber gasket from the rain tray.
    • Remove the rubber gasket from the rain tray.
  3. Lift the tray upwards and away from the vehicle.
    • Lift the tray upwards and away from the vehicle.
结论
4等其他人完成本指南。
This is actually for the cabin air filter inspection cover. To remove the tray you have to pull both wiper arms.
nedhodgson - 回复
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 4
过去的30天: 9
总计 11,865
