跳转到主内容
1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement
你所需要的
  1. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Plastic Rain Tray: 步骤 1 中的图像 1,1
    • Use a #2 Phillips screwdriver to remove the four screws.
  2. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 步骤 2 中的图像 1,1
    • Remove the rubber gasket from the rain tray.
  3. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 步骤 3 中的图像 1,1
    • Lift the tray upwards and away from the vehicle.
  4. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Front Windshield Wipers: 步骤 4 中的图像 1,1
    • Use a flathead screwdriver to remove the cap from the windshield wiper.
  5. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 步骤 5 中的图像 1,1
    • Use a socket wrench to release the passenger-side windshield wiper locking nut.
  6. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 步骤 6 中的图像 1,2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 步骤 6 中的图像 2,2
    • Gently lift up the passenger-side windshield wiper.
  7. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 步骤 7 中的图像 1,1
    • Remove the driver-side windshield wiper in the same fashion.
    My windshield wipers were stuck on like they were welded. I removed them with channel lock pliers. I put the top jaw of the pliers and placed it under the wiper and the bottom claw of the pliers and put it on the mounting bolt. squeezed as hard as I could and Pop! It came loose.
    Nils Stansen - 回复
  8. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: 步骤 8 中的图像 1,2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: 步骤 8 中的图像 2,2
    • Lift up the plastic cover.
    There is a lip on the back side of the cowling. I placed a flat pry bar underneath the cowling from the engine compartment towards the windshield and used the flat lip of the firewall top edge to pry the cowling straight up; not forward or backward but straight up. Mine was stuck with years of debris that turned to a natural glue!
    Nils Stansen - 回复
  9. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 步骤 9 中的图像 1,2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 步骤 9 中的图像 2,2
    • Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover.
    • In a pinch, you can make this tool with a phillips driver bit and end wrench.
  10. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 步骤 10 中的图像 1,1
    • Use a #2 Phillips screwdriver to remove the front two screws.
  11. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 步骤 11 中的图像 1,2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: 步骤 11 中的图像 2,2
    • Gently unplug and lift out the automatic transmission control unit.
结论
8等其他人完成本指南。
Matthew Newsom
于01/05/10注册
39,527 声望
创作了67篇指南
5条评论
Does the new TCU need to be programmed in any way?? Or is it just plug and play.
Paul Newlove - 回复
does it need to be programmed mine needs replacement my gears are not shifting
dean wafula - 回复
got a question if your display light is dim what could be the problem
dean wafula - 回复
Volkswagen tiguan won't start after disconnection, wat can I do to restart it
Jusu Suapay - 回复
thank you very much .
emad_szs - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 136
总计 43,760
