跳转到主内容
1999-2004 Jeep Grand Cherokee Air Filter Replacement
你所需要的
  1. 1999-2004 Jeep Grand Cherokee Air Filter Replacement, Engine Compartment Air Filter: 步骤 1 中的图像 1,1
    • Before you start, make sure the car is off and the parking break is on.
  2. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 步骤 2 中的图像 1,2 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 步骤 2 中的图像 2,2
    • Pull out the hood release handle, which will pop up the hood of the car.
    • The release is located by the driver's seat to the left of the peddles.
  3. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 步骤 3 中的图像 1,2 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 步骤 3 中的图像 2,2
    • Unlatch the hood of the car.
    • Stick your fingers in the gap between the hood and the grill, and feel for a little latch.
    • Press on the latch while also pushing the hood of the car up.
    • Once the hood is unlatched, push it all the way up. It's held there by struts so don't worry about finding the hood prop.
  4. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 步骤 4 中的图像 1,3 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 步骤 4 中的图像 2,3 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 步骤 4 中的图像 3,3
    • The air filter housing is on the right front corner of the engine compartment.
    • Unlatch all four of the clips , which are located at the corners of the air filter housing and hold the housing together.
  5. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 步骤 5 中的图像 1,2 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 步骤 5 中的图像 2,2
    • Gently lift the top half of the housing, and hold it off to the side with one hand.
    • Don't pull the housing too far to the side because it is still attached to the rest of the engine.
    • You can use a flathead screw driver to help pry up the top of the casing.
  6. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 步骤 6 中的图像 1,2 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 步骤 6 中的图像 2,2
    • Remove the old air filter and clean any debris out of the bottom half of the housing.
  7. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 步骤 7 中的图像 1,2 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 步骤 7 中的图像 2,2
    • Place the new filter in the bottom half of the housing.
    • Make sure the air filter is positioned correctly with the mesh side facing up.
  8. 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 步骤 8 中的图像 1,3 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 步骤 8 中的图像 2,3 1999-2004 Jeep Grand Cherokee Air Filter Replacement: 步骤 8 中的图像 3,3
    • Place the top half of the housing back on the bottom half. Make sure the top fits tight back in place.
    • Reattach all four clips on the outside of the casing.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 53
总计 2,785
