跳转到主内容
1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation
你所需要的
  1. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: 步骤 1 中的图像 1,3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: 步骤 1 中的图像 2,3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: 步骤 1 中的图像 3,3
    • Take the Philips screwdriver and remove two Philips head screws on both sides of the high mount brake lamp.
    • Be sure to store the two Philips screws in a safe place so they don't get lost.
  2. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 步骤 2 中的图像 1,2 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 步骤 2 中的图像 2,2
    • Pull out the truck high mount brake/tail light housing.
    • We recommend you pull out the housing with both hands so you don't break the water tight seal.
    • If in the event that you happen you break it, you may have some water leak issues so you would have to fix the high mount brake/tail lamp housing with some glue.
  3. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 步骤 3 中的图像 1,3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 步骤 3 中的图像 2,3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 步骤 3 中的图像 3,3
    • Remove the stock bulbs from its socket.
  4. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 步骤 4 中的图像 1,1
    • Replace with the LED bulb.
    • Test your new LED truck high mount brake lamps to make sure everything works.
    • If the LED lights don't light up, check the polarity by flipping the bulbs 180 degrees.
  5. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 步骤 5 中的图像 1,3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 步骤 5 中的图像 2,3 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: 步骤 5 中的图像 3,3
    • Put back the light housing and screw in the two Philips screws.
结论
Test and enjoy your new LED truck high mount brake/tail replacement lights.
2等其他人完成本指南。
Eric Wu
于01/21/15注册
3,357 声望
创作了23篇指南
2条评论
The problem is there are no screws to remove.
richard - 回复
there are no screws to remove on my 3rd light I can’t change the bulb
richard - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 50
总计 6,008
