简介
为您配备有2.0L Mk4自然吸气发动机的捷达更换机油。 TDI和GLI款采用不同的引擎,操作步骤也不相同,例如所适用的机油。
多年来,3000英里更换一次机油是普遍的做法,但是现在不是这样了。 使用传统机油的发动机可以做到5000英里更换一次机油。 合成机油更加强大,10000英里后也能保持引擎良好工作。
你所需要的
重新拔出机油标尺。
量油尺末端的弯曲长度标记最小和最大油位。 检查以确保您有适量的油。 从最小到最大值需要大约一夸脱。
在将车开到任何地方前,打着车。 让其运转几分钟。 在引擎运转过程中,检查汽车下方是否有任何油滴落。 如果油从排排油塞上滴落,则应首先检查油底壳是否有裂缝。 如果没有裂缝,可以关掉汽车,并拧紧排油塞。 此外,再次检查,汽车机油油位上没有超出极限。
If the author would comment on the dipstick picture I would greatly appreciate it! Otherwise this piece is very helpful. Thanks!
让旧油滤里的残留机油滴干,这通常会需要12-24小时。
带上你的旧机油和旧的油滤前往回收的地方吧。大多数的汽车零件商店和修理厂会无偿回收。 除此之外一些城市或者国家会提供上门回收旧机油和油滤。 详情参见美国石油协会的网站 http://www.recycleoil.org/
28等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
11条评论
Thanks for the article it help me a lot
Be careful on step 22, to much oil on this picture.
You need to be on the top of the bent length, NOT ABOVE.
The stick is stained above the top bend. It doesn’t have oil coating the stick, so it is perfectly fine in the picture. Not too much.
Much appreciated. Very clear.
I would suggest two things: make sure to open/unlock the engine hood BEFORE draining out the old oil, since it is possible the lock fails, in which case you’re left standing there with a car that cannot be driven to a repair shop. Furthermore, unscrewing the oil cap (on the engine block) ensures a better drainage of the oil pan, thanks to the added pressure.
I don’t have a solid answer about gear oil, but there’s some discussion about it in this auto forum http://forums.tdiclub.com/showthread.php... , it may depend on whether you have a manual or an automatic. Any autoparts store should be able to look it up for you. For the oil change listed in this guide you should be using 5W-30.
very nice job about the process, at last someone knows how to post a DIY job on internet, seen lots of bozos out there , I will show this to my son so he can start doing the job himself……… I see you do the same thing as I do , you put the date on a filter LOL
