本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide is applicable for any Accord made between 1998 and 2002.
你所需要的
Use a 10 mm wrench to disconnect the negative battery terminal, followed by the positive terminal.
Unplug the smaller connector first. There's a tab on top of the connector that you have to push downwards, then pull the connector. Make sure to grasp the connector itself, and not the wires.
Do the same with the larger connector. Again, there's a tab on top that needs to be pushed downward.
8等其他人完成本指南。
4条评论
My car radio is deactivated
I need the inside lighting fixture on the front top of the dash
How do you get the radio to turn on
