简介
This guide is applicable for any Accord made between 1998 and 2002.
配件
没有特定配件。
Use a 10 mm wrench to disconnect the negative battery terminal, followed by the positive terminal.
Gently insert a spudger or flathead screwdriver directly underneath the clock, just enough so you can pry out the clock. Perhaps a half inch or so will do it.
Unplug the smaller connector first. There's a tab on top of the connector that you have to push downwards, then pull the connector. Make sure to grasp the connector itself, and not the wires.
Do the same with the larger connector. Again, there's a tab on top that needs to be pushed downward.
8等其他人完成本指南。
3条评论
My car radio is deactivated
I need the inside lighting fixture on the front top of the dash
