跳转到主内容
1998-2002 Honda Accord Spark Plugs Replacement
你所需要的
  1. 1998-2002 Honda Accord Spark Plugs Replacement, Spark Plugs: 步骤 1 中的图像 1,1
    • Begin by locating the four spark plug connectors near the front of the valve cover of your engine.
    • We recommend replacing the spark plugs one at a time to prevent mixing up the spark plug connectors.
    • You can also label the connectors 1-4, left to right, to keep track of which plug you're working on.
    I have 3 on bottom and 3 on top.
    1-3 left to right ,bottom
    Than top 4,5,6 left to right
    Deneen Scully - 回复
  2. 1998-2002 Honda Accord Spark Plugs Replacement: 步骤 2 中的图像 1,2 1998-2002 Honda Accord Spark Plugs Replacement: 步骤 2 中的图像 2,2
    • Grab the top of the spark plug connector and pull upward while rocking the connector around its socket.
    • This may require a significant amount of force.
    • Once the connector has been disconnected from the top of the spark plug, lift it out of the engine.
    • For more slack to move the spark plug connector out of the way, simply pop the spark plug wire out of the closest plastic loom.
  3. 1998-2002 Honda Accord Spark Plugs Replacement: 步骤 3 中的图像 1,3 1998-2002 Honda Accord Spark Plugs Replacement: 步骤 3 中的图像 2,3 1998-2002 Honda Accord Spark Plugs Replacement: 步骤 3 中的图像 3,3
    • At this point, you can peer down into the spark plug hole and see the top of the spark plug.
    • Attach a 5/8" spark plug socket to a 10" ratchet extension, and attach the extenstion to a socket wrench.
    • Lower the spark plug socket down into the spark plug hole and press downward to firmly seat the spark plug in the rubber retainer found inside the socket. Make sure that the hex thread of the socket lines up with the hex thread of the spark plug.
    • Rotate the socket wrench counter-clockwise to loosen the spark plug from the cylinder head.
    • Lift the spark plug out of the cylinder head.
    • Remove the old spark plug from the spark plug socket.
  4. 1998-2002 Honda Accord Spark Plugs Replacement: 步骤 4 中的图像 1,2 1998-2002 Honda Accord Spark Plugs Replacement: 步骤 4 中的图像 2,2
    • Even if you are using pre-gapped spark plugs, it is a good idea to check the gap before installing your new plugs.
    • Insert the thinnest portion of a spark plug gap gauge between the center electrode and the ground electrode of the spark plug.
    • While holding the gauge between the spark plug gap, rotate it until it gently wedges itself into the gap.
    • The distance of the spark plug gap can now be read off the gauge. The factory spec for this vehicle is anywhere from .039 to .043 inches.
  5. 1998-2002 Honda Accord Spark Plugs Replacement: 步骤 5 中的图像 1,3 1998-2002 Honda Accord Spark Plugs Replacement: 步骤 5 中的图像 2,3 1998-2002 Honda Accord Spark Plugs Replacement: 步骤 5 中的图像 3,3
    • Insert a new spark plug into the spark plug socket until it is seated within the rubber retainer inside.
    • Lightly coat the threads of the spark plug in anti-seize lubricant to aid in removal the next time the spark plugs are replaced.
    • Do not get any anti-seize lubricant on either of the two electrodes.
    • Since the rubber retainer inside the spark plug socket holds the spark plug very firmly, you can tape the socket to the extension to aid in removing the socket once the spark plug is installed.
  6. 1998-2002 Honda Accord Spark Plugs Replacement: 步骤 6 中的图像 1,1
    • It is easiest to accomplish this step with the socket wrench disconnected from the extension.
    • Carefully lower the new spark plug down into its hole, being sure not to contact the spark plug with the side of the tube leading to the cylinder head.
    • Once the spark plug has reached the threads in the cylinder head, hand tighten the spark plug.
  7. 1998-2002 Honda Accord Spark Plugs Replacement: 步骤 7 中的图像 1,1
    • Use a torque wrench to tighten the spark plug to a spec of 156 in-lbs (13 ft-lbs).
    • If a torque wrench is unavailable, tighten the spark plugs by hand, and finish with a 1/4-1/2 turn using a socket wrench until snug.
    • Do not over-tighten the spark plugs, as the threads may strip out of the soft aluminum cylinder head.
  8. 1998-2002 Honda Accord Spark Plugs Replacement: 步骤 8 中的图像 1,1
    • Reinstall the spark plug connector and, if necessary, push the spark plug wire back into its plastic loom.
    • Make sure the spark plug connector clicks firmly in place, and double-check all four connectors once you're finished with all the plugs.
    • Repeat this procedure for all four spark plugs.
结论
34等其他人完成本指南。
15条评论
It is a good idea to use compressed air to blow out any debris or dirt in the plug cavity before removing the old plug. You can use an air can from the computer store. A short burst is sufficient.
RZ H - 回复
Hi I have a question. I purchased some spark plugs that have the torque labeled at 21 lbs. I bought I Torque wrench but I found out that by using an extension, I would have to change the torque to a lower setting. Do you know of what number I should set it too ?
Alex Morales - 回复
Actually, it is better to use a higher torque rating, as extensions have torsion, especially the smaller 1/4 or 3/8 size extensions. I would recommend you set it to 22 or 23 foot pounds.
Rick Yao -
It will be nicer if you give specs like the socket size you used various other settings like that ...
Jeanie Marcelle - 回复
i just tuch it it was on then came of and that's it no more
OVATSUG SAEB -
There is a standard “spark plug socket” that comes with most socket wrench sets. As far as I know, they are all the same size.
Note that you should not use an ordinary socket of that size - a spark plug socket has a rubber grommet in it to hold the plug and prevent damage.
shamino -
the spark plug cord came one of and id didn't not want to start just the cranking only
OVATSUG SAEB - 回复
i said honda accord the spark plug connection came one of and then i didn't want to turn on just the cranking
OVATSUG SAEB - 回复
What is the plug caked that sits right above the spark plug wires
Brandon Marsden - 回复
Thanks for sharing such a great blog with all details for a non-technical person like me. As per my personal experience sometime it’s hard to deal with mechanical problems then we need to call an expert from Honda service center like gomechanic to get best service at the lowest price at 24x7.
kasmira khandelwal - 回复
Wire harness won't fire on front3 plugs
ralph bretzman - 回复
Electronics to spark plugs
ralph bretzman -
I recently change my spark blogs and all them but one i wasnt able to change wat do u recommend me doing
Adrian Gonzalez - 回复
Why won't the plug come up out of the hole? It's turns like it's loose enough
Sandra Irwin - 回复
Awesome explanation. Thank you so much for this guide 10/10.
Joe m - 回复
添加评论
浏览统计数据:
过去 24 小时: 22
过去 7 天: 152
过去 30 天: 653
总计 244,741
