跳转到主内容
简介
Use this guide to replace your Honda Accord's distributor rotor. This specific guide was created for a non-VTEC F23A5 engine, but other 4-cylinder Honda engines will be similar enough to follow the same basic steps. You may have to remove the engine cover in later Accord models.
  1. Before disconnecting the spark plug wires, be sure to trace their orientation from the individual cylinders back to the distributor cap. The cylinders are ordered from left to right when viewing the engine from the front of the car, with cylinder #1 being closest to the passenger side of the vehicle. Mark the order of the spark plug wires on the new distributor cap with a silver sharpie marker -- it will make reinstallation much easier.
    • Before disconnecting the spark plug wires, be sure to trace their orientation from the individual cylinders back to the distributor cap.
    • The cylinders are ordered from left to right when viewing the engine from the front of the car, with cylinder #1 being closest to the passenger side of the vehicle.
    • Mark the order of the spark plug wires on the new distributor cap with a silver sharpie marker -- it will make reinstallation much easier.
  2. Disconnect the four spark plug wires from the distributor cap by pulling their connectors straight away from the sockets on the distributor cap.
    • Disconnect the four spark plug wires from the distributor cap by pulling their connectors straight away from the sockets on the distributor cap.
    • It may be helpful to slightly twist the wires as you pull them.
  3. Use a 1/4" drive, 8 mm deep socket to remove the three hex bolts securing the distributor cap to the engine. The position of the third bolt is not visible in the second picture.
    • Use a 1/4" drive, 8 mm deep socket to remove the three hex bolts securing the distributor cap to the engine.
    • The position of the third bolt is not visible in the second picture.
  4. iPhone 电池维修工具包
    只要 $29.99
    Buy Now
    iPhone 电池维修工具包
    只要 $29.99
    Buy Now
  5. Pull the distributor cap away from the engine and set it aside.
    • Pull the distributor cap away from the engine and set it aside.
  6. Use a dental pick or a small screwdriver to gently remove the D-shaped o-ring around the distributor cap flange. Install a new o-ring in the seal recess, making sure that it is sitting flush against the flange.
    • Use a dental pick or a small screwdriver to gently remove the D-shaped o-ring around the distributor cap flange.
    • Install a new o-ring in the seal recess, making sure that it is sitting flush against the flange.
  7. Remove the single #2 Phillips screw securing the distributor rotor to the shaft. Remove the single #2 Phillips screw securing the distributor rotor to the shaft.
    • Remove the single #2 Phillips screw securing the distributor rotor to the shaft.
  8. Pull the distributor rotor straight off its shaft, being careful not to rotate the shaft as you remove it. When installing the new distributor rotor, press it onto the shaft with the screw holes aligned axially.
    • Pull the distributor rotor straight off its shaft, being careful not to rotate the shaft as you remove it.
    • When installing the new distributor rotor, press it onto the shaft with the screw holes aligned axially.
结论
2等其他人完成本指南。
In Step 6, the Phillips screw holding the distributor rotor in place is stuck and it won't turn for me. Any advice on removing that screw, when it is stuck in place? This is on a 1997 Honda Accord LX, non VTEC. Thanks...
CheeseHead1 - 回复
Get a punch screwdriver. It's a tool that as hit the top it twist. Be care full not to hit to hard. Or if u can fit a angle die grinder cut one line through top part of screw. Use a big flat head screwdriver. Do not cut top of bolt too deep stop right before u get to the bottom of the head of bolt
dbo240 - 回复
The screw attaching my rotor is missing. 2001 crv do you know the size?
Trish - 回复
What size is that little screw that holds the distributor rotor?
Francisco Ramirez - 回复
添加评论
浏览统计数据:
过去的24小时: 8
过去的7天: 47
过去的30天: 283
总计 41,341
