Stop the car engine.
Indentify the car battery.
Identify the screw on the right side of the battery which maintains the battery.
WIth the 8mm box end wrench, remove the black (ground) cable.
WIth the 13mm wrench, remove the red cable.
Unscrew the bottom screw identify in step 2 with the 13mm socket wrench.
Remove the old battery.
Insert your new battery and lock the it with the screw.
Grease the battery contacts.
Put back the red cable and then the black one.
Start your car.
取消:我没有完成这个指南。
20等其他人完成本指南。
与3其他贡献者
于04/05/13注册
1,389 声望
创作了4篇指南
徽章: 20
+ 17更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 18
过去 7 天: 123
过去 30 天: 537
总计 56,471
