跳转到主内容
加入维修社区 - 创建账户
1997 Toyota Camry Stop and Tail Light Bulbs Replacement
你所需要的
    1. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement, Stop and Tail Light Bulbs: 步骤 1 中的图像 1,3 1997 Toyota Camry Stop and Tail Light Bulbs Replacement, Stop and Tail Light Bulbs: 步骤 1 中的图像 2,3 1997 Toyota Camry Stop and Tail Light Bulbs Replacement, Stop and Tail Light Bulbs: 步骤 1 中的图像 3,3
      • Open the trunk.
      • Loosen three 15 mm screws using a Phillips #1 screwdriver.
      • Pull the cover clips at the base to remove.
      • Potential for device damage: Do not pull the cover clips prior to unscrewing as the cover clips can break.
      • Remove the cover by folding the cover backwards to expose the bulb assembly.
      询问修复机器人
      添加评论
    2. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: 步骤 2 中的图像 1,2 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: 步骤 2 中的图像 2,2
      • Grab the inner light bulb assembly using your thumb and forefinger.
      • Rotate the bulb assembly a quarter turn counterclockwise.
      • Pull it straight outwards until the bulb is displayed.
      询问修复机器人
      添加评论
    3. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: 步骤 3 中的图像 1,1
      • While holding the assembly, grab the base of the light bulb with your thumb and forefinger.
      • Pull the bulb away from the assembly until it detaches. Discard the old bulb.
      询问修复机器人
      添加评论
    4. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: 步骤 4 中的图像 1,1
      • Grab the new inner tail light bulb 3157 and push it into the bulb assembly.
      • Insert the bulb assembly straight into the socket. Rotate it a quarter turn clockwise to secure it.
      询问修复机器人
      添加评论
    5. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: 步骤 5 中的图像 1,1
      • Repeat this process with the outer light bulb assembly using bulb 904.
      询问修复机器人
      添加评论
    6. 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: 步骤 6 中的图像 1,2 1997 Toyota Camry Stop and Tail Light Bulbs Replacement: 步骤 6 中的图像 2,2
      • Unfold the cover and place it back over the bulb sockets. Push the three cover clips into their sockets .
      • Screw the three 15 mm screws in with Phillips #1 screwdriver to secure the cover.
      询问修复机器人
      添加评论
结论
Your stop and tail lights have been properly replaced and your replace bulb indicator should be off on your dashboard.
取消:我没有完成这个指南。
Ivan Navas
于02/24/21注册
138 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 44
总计 3,471
