跳转到主内容
加入维修社区 - 创建账户
1997 Toyota Camry Exterior Driver-Side Door Handle Replacement
你所需要的
    1. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Gather Tools and New Door Handle: 步骤 1 中的图像 1,2 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Gather Tools and New Door Handle: 步骤 1 中的图像 2,2
      • Get all your tools ready!
      询问修复机器人
      添加评论
    2. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Putting Window Up: 步骤 2 中的图像 1,1
      • Make sure the window is all the way up.
      询问修复机器人
      添加评论
    3. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Removing Plugs: 步骤 3 中的图像 1,1
      • Use a pick tool to remove the two plastic plugs and the plastic trim inside the door release lever.
      询问修复机器人
      添加评论
    4. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Removing Trim Panel & Disconnecting Switch Housing: 步骤 4 中的图像 1,2 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Removing Trim Panel & Disconnecting Switch Housing: 步骤 4 中的图像 2,2
      • Use a flat blade screwdriver to pop out the trim panel.
      • Remove the switch housing from the door by holding the button and disconnecting it.
      询问修复机器人
      添加评论
    5. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Removing Plastic Cover: 步骤 5 中的图像 1,1
      • Use a flat blade screwdriver to pry the small triangular plastic cover on the right side of the window interior.
      询问修复机器人
      添加评论
    6. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Removing Screws: 步骤 6 中的图像 1,2 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Removing Screws: 步骤 6 中的图像 2,2
      • Use a no. 2 Phillips head screwdriver to remove the 5 Phillips head screws from the door panel.
      询问修复机器人
      添加评论
    7. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Removing Bezel: 步骤 7 中的图像 1,2 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Removing Bezel: 步骤 7 中的图像 2,2
      • Use a flat-blade screwdriver to remove the bezel by placing it between the handle and the bezel, starting from the bottom, then the top.
      询问修复机器人
      添加评论
    8. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Removing Door Panel: 步骤 8 中的图像 1,2 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Removing Door Panel: 步骤 8 中的图像 2,2
      • Pop out the bottom of the door panel, then lift and remove the panel.
      询问修复机器人
      添加评论
    9. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Removing Interior Door Handle: 步骤 9 中的图像 1,2 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Removing Interior Door Handle: 步骤 9 中的图像 2,2
      • Use a 10mm socket with ratchet and extension to remove the bolt from the back of the door handle.
      • Rotate the interior door handle the opposite way to release the metal latch rods from the handle and the lock.
      • Remember that the upper is for the lock and the lower is for the handle
      询问修复机器人
      添加评论
    10. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Removing Metal Plate: 步骤 10 中的图像 1,1
      • Use a Phillips head screwdriver to remove the 3 Phillips head screws from the metal plate.
      询问修复机器人
      添加评论
    11. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Removing Weather Shielding: 步骤 11 中的图像 1,2 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Removing Weather Shielding: 步骤 11 中的图像 2,2
      • Carefully remove the weather shielding inside the door panel.
      • Pull the wiring harness through the shielding before finishing removing it.
      • Place the shielding off to the side where it won’t get wrinkled or torn.
      询问修复机器人
      添加评论
    12. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Disconnecting Latch & Lock Rods: 步骤 12 中的图像 1,3 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Disconnecting Latch & Lock Rods: 步骤 12 中的图像 2,3 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Disconnecting Latch & Lock Rods: 步骤 12 中的图像 3,3
      • Disconnect the latch rod from the back of the door handle by flipping up on the plastic lock rod retainer clip.
      • Use a flat blade screwdriver to pry the latch rod out of the handle.
      • For the plastic lock rod retainer clip and rod repeat the same step.
      • The Plastic Lock Rod Retainer Clip is supposed to stay in the hole, but mine is broken, and the new door handle came with a new one.
      询问修复机器人
      添加评论
    13. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Removing Exterior Door Handle: 步骤 13 中的图像 1,2 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Removing Exterior Door Handle: 步骤 13 中的图像 2,2
      • Use a 10mm socket with ratchet and extension to remove the 2 bolts.
      • Lift up on the door handle and pull out to remove it.
      询问修复机器人
      添加评论
    14. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Installing Bolt to New Handle: 步骤 14 中的图像 1,2 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Installing Bolt to New Handle: 步骤 14 中的图像 2,2
      • Use a 10mm socket with ratchet and extension to remove the bolt.
      • Remove the lock from handle and reinstall it into your new handle.
      询问修复机器人
      添加评论
    15. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Installing Exterior Door Handle: 步骤 15 中的图像 1,2 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Installing Exterior Door Handle: 步骤 15 中的图像 2,2
      • Install your new door handle the same way you took out the old one.
      • Use a 10mm socket with ratchet and extension to reinstall the 10mm bolts.
      询问修复机器人
      添加评论
    16. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Reconnecting Latch & Lock Rods: 步骤 16 中的图像 1,2 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Reconnecting Latch & Lock Rods: 步骤 16 中的图像 2,2
      • Reconnect the lock rod into the hole on the bottom of the lock cylinder and snap the yellow lock rod retainer clip into place.
      • Reconnect the latch rod into the back of the door handle and snap the white lock rod retainer clip into place.
      询问修复机器人
      添加评论
    17. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Reinstalling Weather Shielding & Metal Cover: 步骤 17 中的图像 1,3 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Reinstalling Weather Shielding & Metal Cover: 步骤 17 中的图像 2,3 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Reinstalling Weather Shielding & Metal Cover: 步骤 17 中的图像 3,3
      • Reinstall the weather shielding to the inside of the door making sure you put through the wiring
      • Use a Phillips head screwdriver to reinstall the 3 Phillips head screws in the lower metal cover.
      询问修复机器人
      添加评论
    18. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Reinstalling Interior Door Handle: 步骤 18 中的图像 1,3 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Reinstalling Interior Door Handle: 步骤 18 中的图像 2,3 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Reinstalling Interior Door Handle: 步骤 18 中的图像 3,3
      • Reinstall the lock rod into the top and the handle latch rod into the bottom.
      • Connect the hooks from the back of the latch into the door, and slide back to engage them.
      • Use a 10mm socket with ratchet and extension to reinstall the 10mm bolt thats in the back of the handle.
      询问修复机器人
      添加评论
    19. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Reinstalling Door Panel: 步骤 19 中的图像 1,3 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Reinstalling Door Panel: 步骤 19 中的图像 2,3 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Reinstalling Door Panel: 步骤 19 中的图像 3,3
      • Reinstall the door panel and make sure your door lock and window switch wires are pulled through so they don't get stuck behind it.
      • Use a Phillips head screwdriver to reinstall your 5 Phillips head screwdriver on your door panel.
      询问修复机器人
      添加评论
    20. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Reconnecting Electrical Connectors, Bezel, Plugs, & Plastic Cover: 步骤 20 中的图像 1,3 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Reconnecting Electrical Connectors, Bezel, Plugs, & Plastic Cover: 步骤 20 中的图像 2,3 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Reconnecting Electrical Connectors, Bezel, Plugs, & Plastic Cover: 步骤 20 中的图像 3,3
      • Reconnect the electrical connectors on your lock and window switch and place back onto the arm rest.
      • Reconnect the bezel around the interior door handle and reinstall your Phillips head screw.
      • Plug back in all three screw covers and snap back on the black triangular plastic cover.
      询问修复机器人
      添加评论
    21. 1997 Toyota Camry Exterior Driver-Side Door Handle Replacement, Finish Product: 步骤 21 中的图像 1,1
      • Finished!
      询问修复机器人
      添加评论
结论
In conclusion, replacing the exterior door handle on a 1997 Toyota Camry is a manageable repair that can be completed with basic tools and careful attention to detail. By following each step methodically, you can restore proper function to the door and avoid the cost of a professional repair. Taking your time during disassembly and reassembly is key to preventing damage to clips, rods, and trim pieces. Once completed, the new handle should operate smoothly, improving both the usability and appearance of the vehicle.
取消:我没有完成这个指南。
Bryan Contreras
于04/08/26注册
313 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 36
总计 44
