简介
更换'97- '01丰田凯美瑞的油,以提高发动机性能和使用寿命。
多年来,3000英里是石油变化之间等待的正确时间间隔; 但事实并非如此。 传统的油在今天的发动机可以轻松地持续超过5000英里的变化。 合成油更加耐用,维持超过10,000英里的良好发动机性能。
你所需要的
找到位于驾驶员控制台左下方的发动机罩打开杆。 拉动杠杆,直到听到罩子打开。
轻轻抬起罩,并固定罩盖。 闩锁将靠近发动机罩的中心。 拉起发动机罩,将发动机罩打开。
将发动机支撑杆放在位于乘客侧的发动机罩前部的孔中。
让油排出,直到减慢到滴漏。
用抹布或毛巾擦拭排油塞区域。
更换排水塞。 用手将其拧紧,然后使用14毫米盒式扳手或插座完成收紧。
开车,在车下寻找泄漏。 如果有泄漏,请关闭汽车,并确定排水塞或过滤器是否需要拧紧,或者零件是否损坏。
将您的旧油过滤器面朝下放在排油盘中,让所有油排放12-24小时。
将您的旧油和过滤器带回回收设施。 大多数汽车零部件商店和维修店免费接受这些零件。 另外,一些城市和/或县也有一个服务,他们将从家里收集废油和过滤器。 有关更多信息,请参阅http://www.recycleoil.org/
F Y I
I use the K and N 1002 with the nut on the back. U have no problem removing the filter because of the nut. Remember hand tighten only. This filter also fits my 2004 Chevy tracker with the V6 and that one is a pain to get too, but the nut on the back makes it easy. You pay more but it doesn't take all day.
John
John Smith - 回复
32等其他人完成本指南。
由衷感谢以下译者:
94%
笑得像个300斤的孩子正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
14条评论
I have the same toyota rukus car as on this website http://www.toyotarukusclub.com, will this work for it too?
Fantastic instructions
Good information
These directions made it truly easy to use and step by step was perfect
Thanks a lot for the information, very helpful! How can i adjust the odometer?
Use a filter wrench. Use a torque wrench to tighten plug per spec. Use a jack stand at two spots, one there and one toward the rear. Make sure car is in park. Remove stands and lower car BEFORE closing the hood!!!
You forgot one very important part. The washer that goes on the drain plug. If not replaced you could have a small leak.
Totoya has them and they are made of either copper or some other soft material. But the ones I get from Toyata are black. Most people miss this 1 tiny crucial piece .
Always refer to a Toyota manual before getting information on the internet. Even though this was very informative, you should always double check from the dealer or a reputable Mechanic.
Good job thank u
What's the difference between 5w-30 and 10w-30??
Alli Appel - 回复
هل سيارة ابسوم موديل 2001 نفس تقنيات كامري
Thank you for the easy step by step instructions tried to tell girlfriend that she could even do it. I should have reworded that before saying it . But I know how to change the oil. Lol
