跳转到主内容
加入维修社区 - 创建账户
1997-2001 Toyota Camry Headlight Bulb Replacement
你所需要的
  1. 1997-2001 Toyota Camry Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 1,1
    • Prop up your hood.
    • Make sure you prop your hood up with your hood prop rod.
  2. 1997-2001 Toyota Camry Headlight Bulb Replacement: 步骤 2 中的图像 1,1
    • Locate the back of the headlight you plan to replace the bulb in.
    • This will be directly behind the headlight assembly.
    • If you are replacing your left headlight, you may need to remove the battery to have enough room to do this replacement.
  3. 1997-2001 Toyota Camry Headlight Bulb Replacement: 步骤 3 中的图像 1,1
    • Disconnect the headlight.
  4. 1997-2001 Toyota Camry Headlight Bulb Replacement: 步骤 4 中的图像 1,1
    • Remove the rubber cover by pulling on the tab marked "Pull Top" away from you.
  5. 1997-2001 Toyota Camry Headlight Bulb Replacement: 步骤 5 中的图像 1,2 1997-2001 Toyota Camry Headlight Bulb Replacement: 步骤 5 中的图像 2,2
    • Release the bulb by pushing the metal fastener inward and then moving it upwards.
  6. 1997-2001 Toyota Camry Headlight Bulb Replacement: 步骤 6 中的图像 1,1
    • Remove the bulb.
  7. 1997-2001 Toyota Camry Headlight Bulb Replacement: 步骤 7 中的图像 1,1
    • Insert the new bulb. Make sure the metal tabs fit correctly.
    • I've read that touching the glass on the bulb can shorten the life of the bulb, so try not to do that.
结论
To finish your headlight bulb replacement, follow these instructions in reverse order.
16等其他人完成本指南。
Chris Opperwall
于04/04/13注册
1,394 声望
撰写一个指南
1指南评论
The 2000 and 2001 Camry models take 9006 (HB4) bulbs for the low beams and 9005 (HB3) bulbs for the high beams, rather than the 9003 (HB2) linked here -- at least for the North American models I've looked up.
If you have the original owner's manual that came with the car, there's a table of all the bulb types you'll need for different lights in the "Do-It-Yourself Maintenance" section. It doesn't hurt to double check.
rakslice - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 29
过去 30 天: 114
总计 50,738
