跳转到主内容
1997-2001 Jeep Cherokee Brake Light Replacement
你所需要的
  1. 1997-2001 Jeep Cherokee Brake Light Replacement, Brake Light: 步骤 1 中的图像 1,1
    • Open the trunk door. In order to remove the rear light assembly, it must be accessed with the trunk open.
  2. 1997-2001 Jeep Cherokee Brake Light Replacement: 步骤 2 中的图像 1,1
    • Remove the three screws that are holding the rear light assembly to the body of the Jeep. Use the wrench to remove the screws.
    • Each screw is an indented hexagon washer head and is 3/16" in diameter and 3/4" long.
    • All three screws are identical and can be removed in any order.
  3. 1997-2001 Jeep Cherokee Brake Light Replacement: 步骤 3 中的图像 1,1
    • Gently pull the rear light assembly away from the car to gain access to the bulbs and wires.
    • Be careful when pulling away the rear light assembly. The wires will still be attached to the inside of the car.
  4. 1997-2001 Jeep Cherokee Brake Light Replacement: 步骤 4 中的图像 1,1
    • Locate the brake light. Turn the light assembly over and you will see three light bulb sockets. The brake light is the top bulb and the bulb behind the red plastic lens.
  5. 1997-2001 Jeep Cherokee Brake Light Replacement: 步骤 5 中的图像 1,3 1997-2001 Jeep Cherokee Brake Light Replacement: 步骤 5 中的图像 2,3 1997-2001 Jeep Cherokee Brake Light Replacement: 步骤 5 中的图像 3,3
    • Remove the brake light. Twist the light bulb socket clockwise and remove the light bulb socket from the rear light assembly.
  6. 1997-2001 Jeep Cherokee Brake Light Replacement: 步骤 6 中的图像 1,1
    • Remove the bulb by pinching on either side of the bulb and gently pulling the bulb out.
    • Be careful not to force the bulb when pulling as it may damage the bulb socket.
  7. 1997-2001 Jeep Cherokee Brake Light Replacement: 步骤 7 中的图像 1,1
    • Replace with the new bulb. Gently put in the new bulb in the same manner as you removed the old bulb.
  8. 1997-2001 Jeep Cherokee Brake Light Replacement: 步骤 8 中的图像 1,2 1997-2001 Jeep Cherokee Brake Light Replacement: 步骤 8 中的图像 2,2
    • Lock the bulb back in place. Carefully put the bulb back into the light assembly and twist counter clockwise until it locks in place.
  9. 1997-2001 Jeep Cherokee Brake Light Replacement: 步骤 9 中的图像 1,3 1997-2001 Jeep Cherokee Brake Light Replacement: 步骤 9 中的图像 2,3 1997-2001 Jeep Cherokee Brake Light Replacement: 步骤 9 中的图像 3,3
    • Set the light assembly back in place. There is a tab on the bottom of the light assembly that must line up with the hole in the car.
    • The red brake light should be on top.
  10. 1997-2001 Jeep Cherokee Brake Light Replacement: 步骤 10 中的图像 1,1
    • Tighten the three screws back into place. This will fasten the light assembly back onto the car.
    • The order and the positioning of the screws will have no effect on the assembly, because they are all identical.
  11. 1997-2001 Jeep Cherokee Brake Light Replacement: 步骤 11 中的图像 1,1
    • Check the brake light. Have another person step on the brake to ensure proper lighting occurs.
终点
14等其他人完成本指南。
James West
于09/29/15注册
531 声望
撰写一个指南
团队
Cal Poly, Team 15-1, Green Fall 2015 Cal Poly, Team 15-1, Green Fall 2015 的会员
CPSU-GREEN-F15S15G1
5 名成员
创作了6篇指南
3条评论
Very well done and accurate
Kevin white - 回复
It is not easy to get the taillight assembly back into the slot. The side bumper prevents direct access. However, it is possible if done bottom in first gently but firmly.
lionreb - 回复
Amazing blog and share so many creative information. I actually look such website for my car. More information about our business please visit us: https://5starsautoparts.com/
5stars auto parts - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 65
总计 26,570
