简介
Air filters are used to clean and purify the air that goes into your engine. Overtime, they can become filthy and/or clogged. Changing out a nasty filter for a fresh clean one, can result in better performance. Mainly in acceleration. Here is a very good video to reference!
配件
  1. The air filter is located on the right side of the engine. Inside of the medium sized box (Outlined in photo with red box). This is where we will be working primarily
    • The air filter is located on the right side of the engine. Inside of the medium sized box (Outlined in photo with red box).
    • This is where we will be working primarily
  2. Before doing anything, we must remove the sensor attached to the intake tube. The sensor is circled in the photo. Pull up on the grey tab and pull the sensor up gently to release the sensor. Put the sensor in a location that it will not get in the way.
    • Before doing anything, we must remove the sensor attached to the intake tube. The sensor is circled in the photo.
    • Pull up on the grey tab and pull the sensor up gently to release the sensor.
    • Put the sensor in a location that it will not get in the way.
  3. Using the flat-head screwdriver, unscrew the brace until it is very loose. but not completely off! Using the flat-head screwdriver, unscrew the brace until it is very loose. but not completely off!
    • Using the flat-head screwdriver, unscrew the brace until it is very loose. but not completely off!
  4. Simply tug on the rim of the tube and pull downward. It's not meant to come off easily, so it will take some working to get it off. There, your intake tube is now off. Set this somewhere you will not lose it.
    • Simply tug on the rim of the tube and pull downward.
    • It's not meant to come off easily, so it will take some working to get it off.
    • There, your intake tube is now off. Set this somewhere you will not lose it.
  5. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  6. Undue the two tabs on the left and right sides of the filter box and lift the cover out. Put the cover somewhere you will not lose. Put the cover somewhere you will not lose.
    • Undue the two tabs on the left and right sides of the filter box and lift the cover out.
    • Put the cover somewhere you will not lose.
  7. Use the indent under the tab to pull the filter out. The second photo shows why changing the air filter is important. A dirty filter makes it harder for the engine to breathe.
    • Use the indent under the tab to pull the filter out.
    • The second photo shows why changing the air filter is important. A dirty filter makes it harder for the engine to breathe.
    • Put the old filter in the trash, you have no need for it anymore.
  8. The filter must go in the same direction as shown in the first photo. The second photo shows the view of it from the inside of the engine bay. When putting the filter box cover back on, be sure to line up the tabs and holes at the bottom of the box. Then securely snap the tabs back onto the filter box.
    • The filter must go in the same direction as shown in the first photo.
    • The second photo shows the view of it from the inside of the engine bay.
    • When putting the filter box cover back on, be sure to line up the tabs and holes at the bottom of the box. Then securely snap the tabs back onto the filter box.
  9. Push the engine side of the intake tube on first. Be sure to firmly press it back into place. You do not want the intake tube coming off while driving down the road. For the filter-box half of the intake tube, first be sure to place the little tab on the tube inside of the notch as shown in the second photo. Now tighten up that screw. Get it very tight. As with the other end of the intake tube, you do not want it coming off while driving.
    • Push the engine side of the intake tube on first. Be sure to firmly press it back into place. You do not want the intake tube coming off while driving down the road.
    • For the filter-box half of the intake tube, first be sure to place the little tab on the tube inside of the notch as shown in the second photo.
    • Now tighten up that screw. Get it very tight. As with the other end of the intake tube, you do not want it coming off while driving.
  10. This is also critical, forgetting this could be fatal for your car! Line up the plastic tab and push it into place. You should hear a small click.
    • This is also critical, forgetting this could be fatal for your car!
    • Line up the plastic tab and push it into place. You should hear a small click.
    • lightly tug on it to be sure it is in place.
  11. Give both ends of the intake tube a tug to be sure they're tightly in place.
    • Give both ends of the intake tube a tug to be sure they're tightly in place.
    • Now, close the hood and take it for a test drive.
    • If your filter hasn't been changed in a long while, you will notice a huge difference in acceleration performance!
    • When returning from your test drive, open the hood and check the intake tube again. Making sure it did not loosen up during the drive. If it did, be sure to fix this immediately
    • Congratulations! Your air filter has been successfully installed. Now go enjoy your Grand Prix's improved performance!
结论
Your air filter has now been replaced. Your acceleration should be improved! Enjoy!
4等其他人完成本指南。
Scratchitory
于2013年04月25日注册
917 信誉积分
创作了3篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 22
过去的30天: 67
总计 6,035
