跳转到主内容
1997-2003 Chevrolet Malibu Tail Lights Replacement
你所需要的
  1. 1997-2003 Chevrolet Malibu Tail Lights Replacement, Tail Lights: 步骤 1 中的图像 1,1
    • Locate the plastic casing that holds the trunk liner in place, directly behind the tail light.
    • Unscrew the plastic casings.
  2. 1997-2003 Chevrolet Malibu Tail Lights Replacement: 步骤 2 中的图像 1,1
    • Make sure to put some pressure on the tail light itself so it does not fall out when you unscrew it.
    • Unscrew the three plastic wing nuts located behind the tail lights.
  3. 1997-2003 Chevrolet Malibu Tail Lights Replacement: 步骤 3 中的图像 1,1
    • When the tail light assembly comes loose, do not fully remove it because it may damage the connected wires.
    • Carefully pull the tail light away from the car to expose the connected wires.
  4. 1997-2003 Chevrolet Malibu Tail Lights Replacement: 步骤 4 中的图像 1,3 1997-2003 Chevrolet Malibu Tail Lights Replacement: 步骤 4 中的图像 2,3 1997-2003 Chevrolet Malibu Tail Lights Replacement: 步骤 4 中的图像 3,3
    • Unclip the rear panel of the tail light assembly. There are two clips on the top and two on the bottom.
    • Remove the rear panel from the rest of the assembly.
  5. 1997-2003 Chevrolet Malibu Tail Lights Replacement: 步骤 5 中的图像 1,1
    • Do not pull on the bulb, handle it gently because it is fragile.
    • Grab the plastic base of the bulb and gently wiggle it free.
  6. 1997-2003 Chevrolet Malibu Tail Lights Replacement: 步骤 6 中的图像 1,1
    • When handling the new bulbs, avoid touching the glass as much as possible because this can reduce the life of the bulb.
    • Gently push the new bulb into the plastic housing.
  7. 1997-2003 Chevrolet Malibu Tail Lights Replacement: 步骤 7 中的图像 1,1
    • After putting the new bulbs in, turn the desired lights on to check that the newly installed bulbs work correctly.
    • These bulbs have different functions including blinkers, brake lights, hazard lights, and back-up lights. They will only turn on when the necessary signal is sent.
结论
4等其他人完成本指南。
Sank Yang
于10/03/12注册
484 声望
创作了5篇指南
团队
Cal Poly, Team 9-15, Amido Fall 2012 Cal Poly, Team 9-15, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G15
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 34
总计 19,230
