跳转到主内容
1997-2003 Chevrolet Malibu Fluid Check
你所需要的
  1. 1997-2003 Chevrolet Malibu Fluid Check, Brake Fluid: 步骤 1 中的图像 1,3 1997-2003 Chevrolet Malibu Fluid Check, Brake Fluid: 步骤 1 中的图像 2,3 1997-2003 Chevrolet Malibu Fluid Check, Brake Fluid: 步骤 1 中的图像 3,3
    • Use caution while handling brake fluid. Brake fluid strips paint and dissolves plastic.
    • There is a maximum fluid line on the right side of the reservoir. Remove the brake fluid cap and fill the brake fluid to the maximum level line.
  2. 1997-2003 Chevrolet Malibu Fluid Check, Power Steering Fluid: 步骤 2 中的图像 1,3 1997-2003 Chevrolet Malibu Fluid Check, Power Steering Fluid: 步骤 2 中的图像 2,3 1997-2003 Chevrolet Malibu Fluid Check, Power Steering Fluid: 步骤 2 中的图像 3,3
    • Do not overfill the power steering fluid reservoir, as this can overwork the power steering pump and cause it to burn up.
    • Remove the power steering fluid cap. Check the fluid level using the dipstick attached to the cap.
    • Fill the power steering fluid to the appropriate level indicated by the "H" for hot and the "C" for cold.
    • If the car has not been started then the fluid is cold. If the engine has been running for five minutes or more, then it is hot.
  3. 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil: 步骤 3 中的图像 1,3 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil: 步骤 3 中的图像 2,3 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil: 步骤 3 中的图像 3,3
    • Use the yellow handled oil dipstick to check the oil level by removing the dipstick, wiping off the oil, and re-inserting it.
    • Remove the dipstick again and check the oil level. Full level is read on the right side of the dipstick.
  4. 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil Continued: 步骤 4 中的图像 1,3 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil Continued: 步骤 4 中的图像 2,3 1997-2003 Chevrolet Malibu Fluid Check, Engine Oil Continued: 步骤 4 中的图像 3,3
    • If the oil level is below full, add oil to the car by removing the cap labeled "Engine Oil."
    • Add a small amount of oil and repeat Step 3 until the oil level is full.
  5. 1997-2003 Chevrolet Malibu Fluid Check, Radiator Coolant Resrvoir: 步骤 5 中的图像 1,3 1997-2003 Chevrolet Malibu Fluid Check, Radiator Coolant Resrvoir: 步骤 5 中的图像 2,3 1997-2003 Chevrolet Malibu Fluid Check, Radiator Coolant Resrvoir: 步骤 5 中的图像 3,3
    • Make sure the engine is cool before removing the radiator reservoir cap. Radiator coolant needs to be disposed of properly. Visit this link for more information http://www.epa.gov/osw/conserve/material...
    • Remove the radiator reservoir cap and fill it with coolant until it reaches the full level indicator line on the front side of the reservoir.
结论
9等其他人完成本指南。
Sank Yang
于10/03/12注册
484 声望
创作了5篇指南
团队
Cal Poly, Team 9-15, Amido Fall 2012 Cal Poly, Team 9-15, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G15
4 名成员
创作了5篇指南
5指南评论
GM does not want purchasers of used cars to check transmission fluid levels.
Hoping you run it dry so things blow up and you have to buy a new vehicle.
Beginning to dislike GMs
Randy Oman - 回复
I been trying to figure out why the cars shaking so i changed the spark plugs now it shake small kind now the airfilrt needs to be changed out as well but whats with the gas smell when turning on?
Bruce allen - 回复
I am trying to change my starter on my 1997 Malibu Chevrolet SD 2.1L but I am not sure if I can take it out from the top or it's best to go from the bottom? Need to know ASAP.
Renee Howington - 回复
I have a 99 Chevy Malibu what type of starter would work on my car
hernandezchina.1979 - 回复
Cómo saber el nivel de aceite de transmisión automática Malibú 99 que no está ala vista o como se checa gracias me urge
Javier Javy - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 37
过去 30 天: 161
总计 43,164
