跳转到主内容
1997-2003 Chevrolet Malibu Air Filter Replacement
你所需要的
  1. 1997-2003 Chevrolet Malibu Air Filter Replacement, Air Filter: 步骤 1 中的图像 1,2 1997-2003 Chevrolet Malibu Air Filter Replacement, Air Filter: 步骤 1 中的图像 2,2
    • The air filter housing is located on the driver side of the car.
    • Loosen the four housing screws on the plastic air intake box.
    • Do not try to remove these screws from the intake box, as they are not designed to be removed.
  2. 1997-2003 Chevrolet Malibu Air Filter Replacement: 步骤 2 中的图像 1,2 1997-2003 Chevrolet Malibu Air Filter Replacement: 步骤 2 中的图像 2,2
    • Loosen the hose-clamp on the air intake tube located on the side of the air intake box.
    • Remove the air intake tube from the intake box.
  3. 1997-2003 Chevrolet Malibu Air Filter Replacement: 步骤 3 中的图像 1,1
    • Gently lift the top off of the air intake box.
  4. 1997-2003 Chevrolet Malibu Air Filter Replacement: 步骤 4 中的图像 1,1
    • Remove the air filter from the housing and inspect it.
    • If it can not be cleaned, then it should be replaced with a new one.
结论
4等其他人完成本指南。
Sank Yang
于10/03/12注册
484 声望
创作了5篇指南
团队
Cal Poly, Team 9-15, Amido Fall 2012 Cal Poly, Team 9-15, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G15
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 5,381
