跳转到主内容
1997-2003 BMW 5 Series BMW E38 E39 X5 X3 Z4 E46 MP3 Player Replacement
你所需要的
视频概述
A video about installing MP3 Player in BMW E39 http://www.youtube.com/watch?v=_6wg3qTvU....
  1. 1997-2003 BMW 5 Series BMW E38 E39 X5 X3 Z4 E46 MP3 Player Replacement, BMW E38 E39 X5 X3 Z4 E46 MP3 Player: 步骤 1 中的图像 1,1
    • Remove screws holding the CD changer in place (if equipped)
    • Disconnect BMW CD changer 3 pin power plug and 6 pin audio plug from CD changer.
    • Connect MP3 Player to original CD changer connectors
  2. 1997-2003 BMW 5 Series BMW E38 E39 X5 X3 Z4 E46 MP3 Player Replacement: 步骤 2 中的图像 1,3 1997-2003 BMW 5 Series BMW E38 E39 X5 X3 Z4 E46 MP3 Player Replacement: 步骤 2 中的图像 2,3 1997-2003 BMW 5 Series BMW E38 E39 X5 X3 Z4 E46 MP3 Player Replacement: 步骤 2 中的图像 3,3
    • If using the 3 and 6 Pin connector version MP3 player, you will need to connect the unit to a switched power source in order to retain its last song played memory function.
    • A good connection for BMWs built after Jan, 2000 production is the SES wiring plug, which is no longer used in cars that are equipped with the BMW Bluetooth system
    • Switched power is located on pin 24 Violet/White (or Violet/Red see image.
    • If you are also installing the DSP adapter module with your MP3 player you can connect the DSP module adapter to this pin in addition to using pin 14 brown/black for ground.
结论
5等其他人完成本指南。
Martin Bishop
于01/26/12注册
4,373 声望
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 33
总计 13,607
