跳转到主内容
1997-2004 Ford F-150 Air Filter Replacement
你所需要的
  1. 1997-2004 Ford F-150 Air Filter Replacement, Air FIlter: 步骤 1 中的图像 1,3 1997-2004 Ford F-150 Air Filter Replacement, Air FIlter: 步骤 1 中的图像 2,3 1997-2004 Ford F-150 Air Filter Replacement, Air FIlter: 步骤 1 中的图像 3,3
    • Pull on the hood release handle located on the driver's side to the left of the brake pedal to pop the hood.
    • To open the hood, reach into the gap at the front of the truck and feel for the latch.
    • Push it to the left to release it and lift up on the hood.
  2. 1997-2004 Ford F-150 Air Filter Replacement: 步骤 2 中的图像 1,3 1997-2004 Ford F-150 Air Filter Replacement: 步骤 2 中的图像 2,3 1997-2004 Ford F-150 Air Filter Replacement: 步骤 2 中的图像 3,3
    • The air filter box is located in the front right front corner of the engine bay.
    • To disconnect the Mass Airflow Sensor squeeze the tab on the connector and pull it away from the sensor.
  3. 1997-2004 Ford F-150 Air Filter Replacement: 步骤 3 中的图像 1,3 1997-2004 Ford F-150 Air Filter Replacement: 步骤 3 中的图像 2,3 1997-2004 Ford F-150 Air Filter Replacement: 步骤 3 中的图像 3,3
    • Use a flathead screwdriver or a nut driver to loosen the hose clamp that attaches the air filter box to the air inlet tube.
    • When the clamp is loosened set the air inlet tube to the side.
  4. 1997-2004 Ford F-150 Air Filter Replacement: 步骤 4 中的图像 1,3 1997-2004 Ford F-150 Air Filter Replacement: 步骤 4 中的图像 2,3 1997-2004 Ford F-150 Air Filter Replacement: 步骤 4 中的图像 3,3
    • Disconnect the air filter box clamp by pulling the clamp handle towards you.
    • This will loosen the clamp and allow the air box to separate.
  5. 1997-2004 Ford F-150 Air Filter Replacement: 步骤 5 中的图像 1,2 1997-2004 Ford F-150 Air Filter Replacement: 步骤 5 中的图像 2,2
    • To separate air filter box rotate it while pulling the left side of box upwards, removing it from the housing.
    • Once the left side of box is removed reach into the right side of the box and remove the air filter.
    • Dispose of the old air filter and replace with it with the new air filter.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 67
总计 824
