    • Pull the hood latch to release the front hood.
    • Go around to the front of the car and trigger the lever to raise the hood.
    • Lift the hood prop and insert the end into the hood.
    • Locate the oil drain plug underneath the vehicle.
    • Put down some newspaper or cardboard to catch any spills or splashes
    • Slide the oil pan under the drain plug.
  1. Android 维修工具包
    一个新的屏幕或电池就在一个套件之内。
    现在开始购物
    Android 维修工具包
    一个新的屏幕或电池就在一个套件之内。
    现在开始购物
    • Take your 17mm socket and loosen the drain plug.
    • Once loose enough, remove the plug by hand.
    • The oil may be hot, so wear latex gloves when removing the plug.
    • Let the oil drain out until its just a drip.
    • Clean off the plug with a paper towel or rag.
    • Re-screw drain plug back into the oil pan.
    • Make sure it's not to tight or loose - check the owners manual for torque specifications.
    • Locate the Oil Filter on the underside of the car.
    • Remove the oil filter and let the oil drain out.
    • Re-add the new, fresh oil filter.
    • Add 4.8 Quarts of new oil.
结论
另外一个人完成了本指南。
Tim Asp
于2011年01月24日注册
1,297 Reputation
创作了6篇指南
0 Comments
Past 24 Hours: 2
Past 7 Days: 50
Past 30 Days: 230
All Time: 28,076
