跳转到主内容
1996-1998 Acura TL Stereo Head Unit Replacement
你所需要的
  1. 1996-1998 Acura TL Stereo Head Unit Replacement, Center Dash: 步骤 1 中的图像 1,1
    • Using a panel tool or long flat head screwdriver, pry the wood grain trim off and release the clips. Be careful on the thin sections below the head unit as to not snap the trim.
  2. 1996-1998 Acura TL Stereo Head Unit Replacement: 步骤 2 中的图像 1,1
    • Detach the wiring harness from the back of the air conditioning control unit by pushing down on the top middle tab and pulling apart using a screwdriver for leverage if necessary.
  3. 1996-1998 Acura TL Stereo Head Unit Replacement, Stereo Head Unit: 步骤 3 中的图像 1,1
    • Unscrew the four screws from the sides of the deck, circled here.
  4. 1996-1998 Acura TL Stereo Head Unit Replacement: 步骤 4 中的图像 1,1
    • Pull the head unit straight out gently until the two wire harnesses are exposed.
  5. 1996-1998 Acura TL Stereo Head Unit Replacement: 步骤 5 中的图像 1,1
    • Push down on the tabs and remove the wiring from their blue and white harnesses.
    • These two are harder to remove than the others so do not be afraid to use force, or a flathead screw driver for leverage to pop them out.
    • As long as you are pushing the tab and force it out at a straight angle neither the plastic nor the wiring will be damaged.
结论
2等其他人完成本指南。
Brayden
于10/05/12注册
16 声望
创作了5篇指南
团队
Cal Poly, Team 18-42, Regan Fall 2012 Cal Poly, Team 18-42, Regan Fall 2012 的会员
CPSU-REGAN-F12S18G42
4 名成员
创作了5篇指南
2条评论
Awesome! I got an Acura TL 1998
PROJECT zeroto100 - 回复
Thank you for the guid. Can you please make another about how you put aux into this Stereo Head Unit?
Сергей Твердохлеб - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 17
总计 4,220
