跳转到主内容
1995 Toyota Corolla Key Fob Motherboard Replacement
你所需要的
  1. 1995 Toyota Corolla Key Fob Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the single screw securing the key fob shell.
  2. 1995 Toyota Corolla Key Fob Motherboard Replacement: 步骤 2 中的图像 1,1
    • After removing the screw, remove the back cap of the key shell with a flathead screwdriver and twist the screwdriver sideways.
    • Do not lever it upwards to prevent damage to the inner board.
  3. 1995 Toyota Corolla Key Fob Motherboard Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the motherboard inside the now open key without touching any of the inner metal components to prevent damage to the system.
  4. 1995 Toyota Corolla Key Fob Motherboard Replacement: 步骤 4 中的图像 1,1
    • Once you have removed the board, repeat steps 1-2 with the new key and place the motherboard on the rubber.
  5. 1995 Toyota Corolla Key Fob Motherboard Replacement: 步骤 5 中的图像 1,1
    • Place the cap back on the new key and screw everything back into place. Test the key on your vehicle to make sure that all the buttons work.
结论
While this guide shows how to switch the board between shells, unless the key has a removable blade, you will need to get the new one cut with specialized equipment.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 311
