跳转到主内容
1995 Honda CRV Steering Wheel Replacement
你所需要的
  1. 1995 Honda CRV Steering Wheel Replacement, Steering wheel: 步骤 1 中的图像 1,2 1995 Honda CRV Steering Wheel Replacement, Steering wheel: 步骤 1 中的图像 2,2
    • Before replacing your steering wheel you must disconnect your battery terminal charge. Open your hood and locate the negative (-) and positive(+) terminal connection.
    • It is crucial to ensure that proper safety measures are taken when disconnecting a battery
  2. 1995 Honda CRV Steering Wheel Replacement: 步骤 2 中的图像 1,3 1995 Honda CRV Steering Wheel Replacement: 步骤 2 中的图像 2,3 1995 Honda CRV Steering Wheel Replacement: 步骤 2 中的图像 3,3
    • Use a 10 mm socket wrench to loosen each bolt on the two battery connections, and remove the cable (starting with the negative terminal).
    • Additional details on how to safely remove your vehicle's battery can be found here.
    • Make sure to separate the two connections from the battery terminal to prevent any electrical current from flowing
    • After disconnecting the battery, wait at least 10 minutes to allow the electrical current to fully dissipate before attempting to remove the airbag.
    • Make sure to avoid touching the top of the battery terminal while using the socket wrench, as this can generate a spark and potentially cause additional damage.
  3. 1995 Honda CRV Steering Wheel Replacement: 步骤 3 中的图像 1,3 1995 Honda CRV Steering Wheel Replacement: 步骤 3 中的图像 2,3 1995 Honda CRV Steering Wheel Replacement: 步骤 3 中的图像 3,3
    • Find the two screws that secure the steering wheel in place and utilize a T30 Torx screwdriver to loosen each bolt.
    • To remove the T30 Torx screws, turn them counterclockwise. The screws may be hidden and located differently depending on the car model, but they are usually located behind the steering wheel or covered by a small plastic plate on the side
    • Before removing these screws, it is important to ensure that your steering wheel is centered.
  4. 1995 Honda CRV Steering Wheel Replacement: 步骤 4 中的图像 1,3 1995 Honda CRV Steering Wheel Replacement: 步骤 4 中的图像 2,3 1995 Honda CRV Steering Wheel Replacement: 步骤 4 中的图像 3,3
    • To disconnect the airbag connectors, which are typically yellow in color and located at the bottom of the steering wheel, you need to release two grey hooks that keep them in place. Gently lift up the hooks to unlock the connectors, then carefully remove them.
    • Slide the left connector back, this will enable you to disconnect the right connector.
    • Be cautious as there are still wiring connections to consider.
    • When reassembling, make sure to securely place the airbag and horn connections in their designated spots. Place the airbag connector back onto the grey hooks and the horn connector onto the small metal plate
  5. 1995 Honda CRV Steering Wheel Replacement: 步骤 5 中的图像 1,3 1995 Honda CRV Steering Wheel Replacement: 步骤 5 中的图像 2,3 1995 Honda CRV Steering Wheel Replacement: 步骤 5 中的图像 3,3
    • The airbag connection should have either a button or a switch.
    • If there is a button, push it down and then carefully slide the connection up.
    • If there is a switch, carefully toggle it to switch off the horn connector.
    • Now that you have disconnected both the airbag and horn connectors, you can safely remove the airbag from the steering wheel.
  6. 1995 Honda CRV Steering Wheel Replacement: 步骤 6 中的图像 1,3 1995 Honda CRV Steering Wheel Replacement: 步骤 6 中的图像 2,3 1995 Honda CRV Steering Wheel Replacement: 步骤 6 中的图像 3,3
    • Lock the steering wheel before removing the center bolt. This will help keep the wheel firmly in place and prevent it from moving while you remove the bolt.
    • Use a 14 mm socket wrench to loosen the steering column bolt by turning it counter-clockwise.
    • Carefully pull on the steering wheel. You should feel it come loose from the steering column.
    • It is important to avoid removing the center bolt from the column just yet, as this can prevent injury to yourself.
  7. 1995 Honda CRV Steering Wheel Replacement: 步骤 7 中的图像 1,3 1995 Honda CRV Steering Wheel Replacement: 步骤 7 中的图像 2,3 1995 Honda CRV Steering Wheel Replacement: 步骤 7 中的图像 3,3
    • Before removing the steering wheel, it is important to disconnect any other connections that are attached to it. This may include electrical connections for items like cruise control or audio controls. Disconnecting these connections will ensure that the steering wheel can be safely and easily removed from the column.
  8. 1995 Honda CRV Steering Wheel Replacement: 步骤 8 中的图像 1,2 1995 Honda CRV Steering Wheel Replacement: 步骤 8 中的图像 2,2
    • To install the new steering wheel, align the splines on the steering column with those on the new steering wheel. Carefully press the steering wheel onto the column until it is fully seated. Then, tighten the center bolt using a 14 mm socket wrench in a clockwise rotation.
    • When removing your steering wheel, it is important to take note of how it was positioned to ensure that you install the new steering wheel in the correct orientation.
    • Additionally, it is essential to ensure that the new steering wheel is compatible with the specific make and model of your car.
    • Be sure not to overtighten the bolt, as this can cause damage to the steering column
  9. 1995 Honda CRV Steering Wheel Replacement: 步骤 9 中的图像 1,3 1995 Honda CRV Steering Wheel Replacement: 步骤 9 中的图像 2,3 1995 Honda CRV Steering Wheel Replacement: 步骤 9 中的图像 3,3
    • To reattach the airbag carefully reconnect both the horn and airbag connectors to the back of the airbag module
    • Align the airbag with its mounting location on the steering wheel and secure it
  10. 1995 Honda CRV Steering Wheel Replacement: 步骤 10 中的图像 1,3 1995 Honda CRV Steering Wheel Replacement: 步骤 10 中的图像 2,3 1995 Honda CRV Steering Wheel Replacement: 步骤 10 中的图像 3,3
    • Use a T30 Torx screwdriver to reattach the two Torx screws on either the side or back of your steering wheel, depending on the specific model of your car. Make sure to tighten them securely but not excessively
    • To safely secure these screws, rotate them in a clockwise direction.
    • Attach any plastic coverings that were removed earlier during the disassembly process, if applicable to your car model.
  11. 1995 Honda CRV Steering Wheel Replacement: 步骤 11 中的图像 1,3 1995 Honda CRV Steering Wheel Replacement: 步骤 11 中的图像 2,3 1995 Honda CRV Steering Wheel Replacement: 步骤 11 中的图像 3,3
    • Reconnect the battery by first attaching the positive terminal cable and then the negative terminal cable. Use a 10 mm socket wrench to tighten each bolt. It's important to tighten the bolts securely, but be careful not to over-tighten them as this can cause damage to the battery or its connections.
    • To secure each bolt, use a clockwise rotation with the 10 mm socket wrench.
结论
Congratulations on successfully reattaching a new steering wheel to your car! Replacing a steering wheel may seem like a daunting task, but by following the proper steps and taking necessary safety precautions, you were able to accomplish it. Remember to take your time and be patient when working on your car. We hope this guide was helpful to you and wish you the best of luck with your newly installed steering wheel.
2等其他人完成本指南。
yael hernandez
于04/03/23注册
247 声望
撰写一个指南
团队
CSU Los Angeles, Team 1-12, Briggs Spring 2023 CSU Los Angeles, Team 1-12, Briggs Spring 2023 的会员
CSULA-BRIGGS-S23S1G12
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 65
总计 652
