跳转到主内容
1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement
你所需要的
  1. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement, Front and rear wiper blades: 步骤 1 中的图像 1,1
    • Get your wipers in the service position by lifting the wiper arm up until it stands on its own.
  2. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 2 中的图像 1,3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 2 中的图像 2,3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 2 中的图像 3,3
    • Unlatch the cover on the old wiper blade from the arm.
  3. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 3 中的图像 1,2 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 3 中的图像 2,2
    • Firmly grasp the wiper blade and pull the wiper blade towards the car.
    • Turn the wiper blade 90 degrees so that it is perpendicular to the wiper arm.
    • Note: Use a 'J' motion to unhook the wiper blade from the wiper arm.
    • Pull the wiper blade away from the wiper arm.
  4. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 4 中的图像 1,2 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 4 中的图像 2,2
    • Rest the wiper arm on a towel.
    • Putting the wiper arm down removes the risk of it falling over and placing the wiper arm on a towel removes the risk of scratching the windshield.
  5. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 5 中的图像 1,2 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 5 中的图像 2,2
    • Prepare the new wiper blade.
    • Note: There are several different types of adapters. The 4runner uses a J-hook adapter.
    • Refer to the instruction manual from the new wiper blade to ensure you have the correct adaptor attached.
  6. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 6 中的图像 1,3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 6 中的图像 2,3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 6 中的图像 3,3
    • Lift the wiper arm from the down position back into the service position.
    • Insert the wiper arm perpendicular to the wiper blade in the hole.
    • Insert the J-hook into the wiper blade.
    • Note: When inserting, make a 'J' type motion.
    • Turn the wiper blade so that it is parallel to the wiper arm.
    • Firmly grasp the wiper blade and shift it away from the wiper arm until you hear an audible click that confirms that it is secured.
  7. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 7 中的图像 1,1
    • Close the latch on the new wiper blade.
  8. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 8 中的图像 1,2 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 8 中的图像 2,2
    • Remove the towel from the windshield and lower the wiper arm back down.
  9. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 9 中的图像 1,3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 9 中的图像 2,3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 9 中的图像 3,3
    • Repeat the previous eight steps for the second wiper blade.
  10. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 10 中的图像 1,3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 10 中的图像 2,3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 10 中的图像 3,3
    • Remove the two Phillips screws from the rear wiper assembly.
    • The screws will be reused for this part.
    • Place a towel underneath the wiper arm.
  11. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 11 中的图像 1,3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 11 中的图像 2,3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 11 中的图像 3,3
    • Place the old wiper fixture onto the new wiper blade.
  12. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 12 中的图像 1,2 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 12 中的图像 2,2
    • Screw in the rear wiper assembly hand-tight.
    • Do not fully tighten the screws.
  13. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: 步骤 13 中的图像 1,1
    • Align the rear wiper assembly and tighten the screws once it is aligned.
结论
Replacing your wiper blades following the steps outlined in this guide is a simple yet crucial maintenance task to ensure optimal performance and safety on the road. By regularly inspecting and replacing worn-out blades, you can maintain clear visibility and confidence in various weather conditions, ultimately enhancing your driving safety.
另外一个人完成了本指南。
OptimusPrime
于04/15/24注册
217 声望
撰写一个指南
团队
UC Davis, Team 2-7, Morris Spring 2024 UC Davis, Team 2-7, Morris Spring 2024 的会员
UCD-MORRIS-S24S2G7
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 30
总计 98
