简介
为您的 '95-'01 本田 CRV 更换机油来提升引擎工作和寿命。
一般来说每3000英里更换一次机油。 然而这个里程应该根据您的维修情况,汽车年龄,和汽车驾驶的里程和驾驶习惯而决定。
合成油的使用可以帮助减少发动机的磨损,并且对于较旧的发动机来说是可取的,或者如果您的驾驶需要频繁启停。
你所需要的
找到发动机盖释放拉手。 它位于驾驶员控制台的左侧,就位于行李箱释放拉手下面。
拉动拉手,直到听到发动机罩发出声音。
去汽车前部,找到发动机罩释放闩锁。 它位于引擎盖下,稍微向着乘客侧。
抬起发动机罩释放闩锁并抬起发动机盖。
将发动机支撑杆的末端放置在的驾驶员侧由箭头标记的发动机盖的孔中。
找到油尺。 它位于发动机前侧中心线上。
拉出油尺,将其擦干,将其放回其孔中,再次取出。
观察量油尺末端的油位。 它应该在两个孔之间或略高于顶部。
如果机油位低于油尺的底部孔,请加油。 将油尺放在孔中。
I usually ensure mine is exactly on the upper mark.
Recently, the mechanic put excess oil so it went way above the upper mark, so I decided to lower it by pulling some out through a pipe attached to a syringe, because the pipe kept bending, I fastened it to a straw using a masking tape, the drain was going on well until the tape at the tip slipped and remained inside the sump /oil pan.
Is there need to worry or the oil pickup screen will prevent it from doing any damage until my next oil change?
Thanks.
打着车,在车下寻找是否漏油。 如果有漏油,请关闭汽车,并确定排油塞或油滤是否需要拧紧,或者是零件损坏。
运行发动机几分钟后,让它冷却至少一个小时,重新检查油位。 如果油位高于量油尺顶孔的1/2“,则需要排出油,如果油位低于量油尺的底部孔,则需要加油。
让旧油滤残留的油滴干,这通常会需要12-24小时。
带上你的旧机油和旧的油滤前往回收的地方吧。大多数的汽车零件商店和修理厂会无偿回收。 除此之外一些城市或者国家会提供上门回收旧机油和油滤。 详情参见美国石油协会的网站 http://www.recycleoil.org/
30等其他人完成本指南。
由衷感谢以下译者:
100%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
13条评论
The filter is easier and not as messy to replace if you replace it from above. This also keeps debris from getting on the filter gasket.
There is even a small hole in the intake manifold so you can see what the filter threads onto.
if the engine reducing oil whats the cause is there any problem, kindly guide me
mashkoor77 - 回复
Check crank shaft seal (front/rear) and Head cylinder seal areas. Apart from that visit the dealership. Something as minor as an oil pressure sensor could also do that. Again your best bet is to go to a trust worthy auto shop by reviews or a well established and rated dealership. Any place else you'll increase your chances to be cheated.
Remove, and install a new filter, along with a clean gasket plug.
Mate, what do we use in Japanese Variant of Honda CR-V 2.0 Sport k20a4 engine type? Which grade engine oil? I've been using 5W30 Idemitsu API SM grade. I'm thinking to go down to 0W20 API SN, ILSAC GF-5 fully synthetic Idemitsu for this VTEC. Would adding stp fuel line and injector cleaner along with regular flush and engine synthetic base STP additives do harm?
Replacing it from above? Not on my 97 CR-V Unless you have very skinny arms with 2 double jointed elbows.
This was very educating on my part
This oil filter indeed is the hardest one i had . i thought Japanese liked to make things easier. My Toyota was much easier
Synthetic, semi-synthetic or mineral oil?
Synthetic is best, keeps your engine cleaner and has a longer change interval.
I've been using shell helix ultra 5w40 but decided to try out bizol 5w30 allround Hc-Synthese to see how it improves fuel economy.
That's after using bizol oil system clean plus o90 to clean and restore the engine's compression, works great for me.
Dun -
Thanks.
