跳转到主内容
简介
This guide shows how to remove the interior door panels to access multiple components. The method is almost exactly the same for the passenger's side, except there is no connector for the side-view mirror controls.
  1. Remove the plastic Phillips screw towards the front of the door panel. This screw is part of a two-piece securing mechanism. Do not apply force directly onto the screw head, because it will continue to slip into the plastic clip.
    • Remove the plastic Phillips screw towards the front of the door panel.
    • This screw is part of a two-piece securing mechanism. Do not apply force directly onto the screw head, because it will continue to slip into the plastic clip.
    • Use a flathead screwdriver to remove the plastic clip that holds the screw.
  2. Unscrew the Phillips screw in the bottom of the door panel cup. Lift the cup out of the the door panel.
    • Unscrew the Phillips screw in the bottom of the door panel cup.
    • Lift the cup out of the the door panel.
  3. Insert a very thin flathead screwdriver blade into the small gap towards the rear of the car on the plastic screw cover near the door handle. Unscrew the Phillips screw underneath the screw cover.
    • Insert a very thin flathead screwdriver blade into the small gap towards the rear of the car on the plastic screw cover near the door handle.
    • Unscrew the Phillips screw underneath the screw cover.
  4. iPhone 电池维修工具包
    只要 $29.99
    Buy Now
    iPhone 电池维修工具包
    只要 $29.99
    Buy Now
  5. Remove the plastic cover at the base of the C-pillar by pulling it directly away from the window. The cover is held in place by a metal clip, so some force will be required to free it.
    • Remove the plastic cover at the base of the C-pillar by pulling it directly away from the window.
    • The cover is held in place by a metal clip, so some force will be required to free it.
    • In addition to the metal clip, two small tabs at the bottom of the cover keep it in place. Gently lift the corner of the door panel to remove the tabs from their respective holes in the door.
  6. Using firm pressure, pull the door panel away from the door. Start at the top right, and work down the side, across the bottom, and up the opposite side. Multiple clips hold the door panel in place. the door panel will jerk as each clip is freed from its position. Multiple clips hold the door panel in place. the door panel will jerk as each clip is freed from its position.
    • Using firm pressure, pull the door panel away from the door. Start at the top right, and work down the side, across the bottom, and up the opposite side.
    • Multiple clips hold the door panel in place. the door panel will jerk as each clip is freed from its position.
  7. Pull the bottom of the door panel away from the door, and lift the entire panel off the door. Do not try to completely remove the door panel yet, as it is still attached by a number of electrical connectors.
    • Pull the bottom of the door panel away from the door, and lift the entire panel off the door.
    • Do not try to completely remove the door panel yet, as it is still attached by a number of electrical connectors.
  8. Push down on the small tab and pull the connector directly away from its socket to disconnect the power lock switch. Use the same method described above to remove the connector for the tweeter. Press the tab on the bottom of the larger green connector to disconnect the side-view mirror controls.
    • Push down on the small tab and pull the connector directly away from its socket to disconnect the power lock switch.
    • Use the same method described above to remove the connector for the tweeter.
    • Press the tab on the bottom of the larger green connector to disconnect the side-view mirror controls.
  9. Disconnect the power window connector. You may now remove the entire door panel.
    • Disconnect the power window connector.
    • You may now remove the entire door panel.
结论
3等其他人完成本指南。
David Hodson
于2010年04月13日注册
134,840 信誉积分
创作了127篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 27
过去的30天: 127
总计 16,340
