跳转到主内容
1994-2004 Ford Mustang Headlight Replacement
你所需要的
  1. 1994-2004 Ford Mustang Headlight Replacement, Headlights: 步骤 1 中的图像 1,2 1994-2004 Ford Mustang Headlight Replacement, Headlights: 步骤 1 中的图像 2,2
    • To open the hood, pull the release lever by your foot break inside the car.
  2. 1994-2004 Ford Mustang Headlight Replacement: 步骤 2 中的图像 1,2 1994-2004 Ford Mustang Headlight Replacement: 步骤 2 中的图像 2,2
    • To raise the hood, lift up on handle at the front of the hood.
  3. 1994-2004 Ford Mustang Headlight Replacement: 步骤 3 中的图像 1,1
    • Pull on the edges until the cover pops off revealing the nut shown in the next step.
  4. 1994-2004 Ford Mustang Headlight Replacement: 步骤 4 中的图像 1,2 1994-2004 Ford Mustang Headlight Replacement: 步骤 4 中的图像 2,2
    • Using the 11mm wrench, remove the nut.
  5. 1994-2004 Ford Mustang Headlight Replacement: 步骤 5 中的图像 1,1
    • Gently pull out the side paneling using your hands.
  6. 1994-2004 Ford Mustang Headlight Replacement: 步骤 6 中的图像 1,2 1994-2004 Ford Mustang Headlight Replacement: 步骤 6 中的图像 2,2
    • Take out the turn signal light by twisting it. Remove the side panel.
  7. 1994-2004 Ford Mustang Headlight Replacement: 步骤 7 中的图像 1,2 1994-2004 Ford Mustang Headlight Replacement: 步骤 7 中的图像 2,2
    • Remove the bulb from the connector by pulling the two apart.
    • Connect the new bulb to the connector.
  8. 1994-2004 Ford Mustang Headlight Replacement: 步骤 8 中的图像 1,1
    • In the same area where you removed the screw, remove the clip by hand or use needle nose pliers.
  9. 1994-2004 Ford Mustang Headlight Replacement: 步骤 9 中的图像 1,2 1994-2004 Ford Mustang Headlight Replacement: 步骤 9 中的图像 2,2
    • Identify the three retainers. Two of them are on the same side from which the metal clip was removed. The third is on the opposite side, shown in the next step.
    • Slide the 12mm wrench over the retainer and push until you are able to remove the headlight.
  10. 1994-2004 Ford Mustang Headlight Replacement: 步骤 10 中的图像 1,2 1994-2004 Ford Mustang Headlight Replacement: 步骤 10 中的图像 2,2
    • This is the third retainer.
    • To push the retainers in so that I was able to remove the headlight, I pressed the handle of the wrench against the metal part of the retainers and pushed.
  11. 1994-2004 Ford Mustang Headlight Replacement: 步骤 11 中的图像 1,2 1994-2004 Ford Mustang Headlight Replacement: 步骤 11 中的图像 2,2
    • Similar to removing the turn signal, twist the headlight connector and remove the headlight from the bulb.
    • Disconnect the bulb from the connector by pulling the two apart and connect the new bulb. Attach the new bulb to the connector.
结论
另外一个人完成了本指南。
一条评论
I am looking for a set of RHD headlights for my 1994 Mustang Cobra.
outlbw - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 51
总计 1,755
