跳转到主内容
1992-1999 BMW 3 Series Oil Replacement
你所需要的
  1. 1992-1999 BMW 3 Series Oil Replacement, Oil: 步骤 1 中的图像 1,2 1992-1999 BMW 3 Series Oil Replacement, Oil: 步骤 1 中的图像 2,2
    • Open the hood of the car by first pulling the black lever located in the drivers side footwell.
    • Lift upward on the latch located underneath the hood to release the hood.
  2. 1992-1999 BMW 3 Series Oil Replacement: 步骤 2 中的图像 1,2 1992-1999 BMW 3 Series Oil Replacement: 步骤 2 中的图像 2,2
    • Jack up the car using the jack points located underneath the sides of the car.
    • Tip: it is advised to use Jackstands to support the car in case of jack failure.
    • Tip 2: It may only be necessary to lift one corner of the car in order to change the oil. The right front jack point seems to be the best for this.
  3. 1992-1999 BMW 3 Series Oil Replacement: 步骤 3 中的图像 1,3 1992-1999 BMW 3 Series Oil Replacement: 步骤 3 中的图像 2,3 1992-1999 BMW 3 Series Oil Replacement: 步骤 3 中的图像 3,3
    • Place the oil pan underneath the plug
    • Using a 17mm socket, remove the drain plug.
    • Allow the oil to fully drain into the oil pan.
    • Reinstall the drain plug after the the oil stops dripping from the drain hole.
  4. 1992-1999 BMW 3 Series Oil Replacement: 步骤 4 中的图像 1,3 1992-1999 BMW 3 Series Oil Replacement: 步骤 4 中的图像 2,3 1992-1999 BMW 3 Series Oil Replacement: 步骤 4 中的图像 3,3
    • Remove the Oil Filter Housing bolt using a 13mm socket. Lift upwards on the oil filter housing cap to remove it.
    • Lift the old oil filter straight up to remove it. Place a towel underneath it as you lift to catch any dripping oil.
    • While the oil filter is out, inspect the gaskets on the oil filter housing cap and bolt. Replace if necessary.
    • Install the new oil filter and reinstall the oil filter housing.
  5. 1992-1999 BMW 3 Series Oil Replacement: 步骤 5 中的图像 1,3 1992-1999 BMW 3 Series Oil Replacement: 步骤 5 中的图像 2,3 1992-1999 BMW 3 Series Oil Replacement: 步骤 5 中的图像 3,3
    • Remove the oil filler cap and slowly pour seven quarts of oil into the engine.
    • Pull the Dipstick out and inspect the oil level. The oil level should be between the two marked lines.
结论
Place the oil cap back on, close the hood, and lower the car. You have now successfully changed the oil on your BMW E36.
2等其他人完成本指南。
Geoff Wacker
于09/30/13注册
89,934 声望
创作了89篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 58
过去 30 天: 186
总计 5,126
