简介
Has your "Brake Light Failure" warning come up on your On Board Check computer? If so, there is a good chance the brake light bulb has failed and requires replacement.
你所需要的
Determine which brake light is out. Have a friend step on the brake and see which light does not illuminate.
In the trunk, locate the plastic cover that protects the taillight. Turn the handle clockwise (as shown by the arrow above the handle) and gently pull outwards.
To determine whether or not a bulb is burnt, check for a connection break in the bulb. In the image shown, wires run continuously between both connections. This means the bulb is working correctly and can be installed.
Insert the new bulb into the white housing and turn clockwise to install.
The plastic carriers only fit into the taillight carrier one way. The fit is very snug against the metal ground.
Align the two plastic tabs with the indents in the metal sheet. Push hard inward while twisting clockwise until the bulb is horizontal, similar to the other four bulbs. When the bulb fits correctly, you will hear a loud snap.
7等其他人完成本指南。
