跳转到主内容
1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement
你所需要的
  1. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement, Pressure Regulator Fuel Return Line: 步骤 1 中的图像 1,2 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement, Pressure Regulator Fuel Return Line: 步骤 1 中的图像 2,2
    • Pull the hood latch located underneath and left of the steering wheel until it unlatches. An audible "pop" will come from the hood when it has unlatched.
  2. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 步骤 2 中的图像 1,3 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 步骤 2 中的图像 2,3 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 步骤 2 中的图像 3,3
    • Now that the internal latch is opened, a latch underneath the hood must also be unlatched. Put your fingers underneath the hood and lift up on the latch above and right of the Toyota emblem.
    • Remove the hooked end of the hood propping rod and allow it to pivot at the driver's side; place the hooked end in its receptacle to prop the hood.
  3. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 步骤 3 中的图像 1,2 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 步骤 3 中的图像 2,2
    • Inspect the line for damage such as cracks, holes, and fuel seeps.
    • Continue the repair if it shows signs of these failures. Otherwise, the fuel leak is coming from elsewhere.
  4. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 步骤 4 中的图像 1,2 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #2 Screwdriver to loosen the hose clamps on the line until they move freely and are not constricting the hose.
    • Do not entirely unscrew the clamps, as they can be difficult to work with when fully unscrewed.
  5. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 步骤 5 中的图像 1,3 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 步骤 5 中的图像 2,3 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 步骤 5 中的图像 3,3
    • Firmly grip the hose and pull one end outwards parallel from the main line. Repeat the process on the other end of the line.
  6. 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 步骤 6 中的图像 1,2 1989-1995 Toyota SR5 Pickup Fuel Return Line Replacement: 步骤 6 中的图像 2,2
    • Remove the hose clamps from the damaged line. Straighten the used line out and place it alongside the new hose, then cut a piece the same length with the hose cutter (a sharp knife will also work fine).
    • Place the hose clamps on the new hose. There is no need to replace the old hose clamps.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 30
过去 30 天: 123
总计 3,446
