跳转到主内容
加入维修社区 - 创建账户
1988-1994 Nissan Model 240SX Steering Wheel Replacement
你所需要的
    1. 1988-1994 Nissan Model 240SX Steering Wheel Replacement, Steering Wheel: 步骤 1 中的图像 1,2 1988-1994 Nissan Model 240SX Steering Wheel Replacement, Steering Wheel: 步骤 1 中的图像 2,2
      • Gather the hardware, tools and protective equipment.
      询问修复机器人
      添加评论
    2. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 2 中的图像 1,1
      • Straighten the steering wheel and remove the key from the ignition.
      询问修复机器人
      添加评论
    3. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 3 中的图像 1,3 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 3 中的图像 2,3 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 3 中的图像 3,3
      • Grip the steering wheel horn pad, placing your fingertips at the edges.
      • Gently pull it straight towards you and the clips will release it.
      询问修复机器人
      添加评论
    4. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 4 中的图像 1,1
      • Use a paint marker to mark a reference point for the top center of the steering wheel on the face of the steering shaft.
      询问修复机器人
      添加评论
    5. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 5 中的图像 1,2 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 5 中的图像 2,2
      • Using a 19mm socket and ratchet, loosen the steering wheel retainer nut and remove it.
      询问修复机器人
      添加评论
    6. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 6 中的图像 1,2 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 6 中的图像 2,2
      • Place the puller tool on the wheel aligning the steering shaft with the press head and the two threaded holes in the steering wheel with the holes in the ears of the puller.
      • Run the bolts, from the puller tool, through the holes in the ears and thread them into the steering wheel hand tight.
      询问修复机器人
      添加评论
    7. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 7 中的图像 1,1
      • Slowly tighten the press shaft until the steering wheel releases.
      • This should not take much force to accomplish. If something starts bending or you have to use excessive force tightening the shaft, stop, reinstall the steering wheel retaining nut, and take the vehicle to a professional.
      询问修复机器人
      添加评论
    8. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 8 中的图像 1,1
      • Install the steering wheel hub onto the steering shaft, aligning the top center mark on the hub with the paint mark you made in Step 4.
      询问修复机器人
      添加评论
    9. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 9 中的图像 1,2 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 9 中的图像 2,2
      • Reinstall the steering wheel retaining nut torqueing it down to 29 ft*lb using a torque wrench.
      询问修复机器人
      添加评论
    10. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 10 中的图像 1,3 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 10 中的图像 2,3 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 10 中的图像 3,3
      • Place the inner horn retainer ring in-between the new steering wheel and hub, aligning the six bolt holes, and place one screw, finger tight, in the hub to temporarily hold everything in place.
      询问修复机器人
      添加评论
    11. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 11 中的图像 1,3 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 11 中的图像 2,3 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 11 中的图像 3,3
      • Make the wiring connections for the horn.
      询问修复机器人
      添加评论
    12. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 12 中的图像 1,2 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 12 中的图像 2,2
      • Press the horn into the inner horn retainer.
      询问修复机器人
      添加评论
    13. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 13 中的图像 1,3 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 13 中的图像 2,3 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 13 中的图像 3,3
      • Hold the assembly steady and remove the screw that was temporarily installed.
      • Place the outer horn retainer over the horn aligning the bolt pattern.
      • Reinsert the screw to temporarily hold the steering wheel assembly together.
      询问修复机器人
      添加评论
    14. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 14 中的图像 1,2 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 14 中的图像 2,2
      • Place a drop of low strength thread locking compound to each screw and thread them into the steering wheel hub.
      • Do not use excessive thread locking compound. It only takes a drop. This step is to ensure the screws do not loosen due to vibrations.
      询问修复机器人
      添加评论
    15. 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 15 中的图像 1,2 1988-1994 Nissan Model 240SX Steering Wheel Replacement: 步骤 15 中的图像 2,2
      • Tighten these screws using a 3 mm hex wrench.
      • Tighten the screws in a "star" pattern sequence starting with the bolt circled in red.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
GCV Engineering
于04/12/17注册
141 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 39
总计 4,482
