简介
Replacing the spark plugs in your SOHC inline-4 engine may be one of the quickest and easiest ways to provide a nice tune up for your Volvo 240. There is no real need to replace spark plug wires unless one breaks or fails, so see your manufacturer's service manual for recommended replacement intervals. Misfiring or a rough idle may be signs of one or more bad spark plug wires.
There are many aftermarket companies who manufacture spark plug wires that promise to increase performance and fuel economy. However, the most reliable and longest-lasting wires are usually OEM wires from the car's manufacturer. Factory spark plug wires can go hundreds of thousands of miles before requiring replacement.
工具
无需工具。
配件
  1. To avoid any confusion between which wire goes to which spark plug, replace spark plug wires one at a time. You may want to mark either the old or new wires to remind yourself which ones you've changed.
    • To avoid any confusion between which wire goes to which spark plug, replace spark plug wires one at a time. You may want to mark either the old or new wires to remind yourself which ones you've changed.
    • Disconnect the spark plug wire from the distributor cap by pulling it straight up.
  2. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Gently twist the spark plug boot back and forth and pull up to remove it from the spark plug. When installing your new spark plug wires, it's a good idea to apply dielectric grease to the spark plug boots to prevent the electrical connections from being damaged by water or debris.
    • Gently twist the spark plug boot back and forth and pull up to remove it from the spark plug.
    • When installing your new spark plug wires, it's a good idea to apply dielectric grease to the spark plug boots to prevent the electrical connections from being damaged by water or debris.
结论
Install your new spark plug wires in the same manner that you removed the old ones.
2等其他人完成本指南。
David Hodson
于2010年04月13日注册
133,448 信誉积分
创作了127篇指南
Doing this today. Thanks for the clear, reassuring steps to get it done :)
jeconnol - 回复
These directions were great! Thank you. I got the wires on in about 40 minutes. Oh, and I’m a girlie girl. :)
Nancy - 回复
浏览统计数据:
过去的24小时: 1
过去的7天: 4
过去的30天: 19
总计 3,069
