跳转到主内容
1986-1993 Volvo 240 Front Brake Caliper Replacement
你所需要的
  1. 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Wheels: 步骤 1 中的图像 1,3 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Wheels: 步骤 1 中的图像 2,3 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Wheels: 步骤 1 中的图像 3,3
    • Jack up the front of the car and place it on jack stands.
    • Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death.
    • Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
    • The wheel lug nuts should be torqued to 85 ft-lbs when the wheels are put back on the car.
    • Pull the front wheel off the wheel lugs and set it aside.
  2. 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Calipers: 步骤 2 中的图像 1,2 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Calipers: 步骤 2 中的图像 2,2
    • Use a 15 mm box end wrench to remove the two bolts on the back of the brake caliper.
  3. 1986-1993 Volvo 240 Front Brake Caliper Replacement: 步骤 3 中的图像 1,2 1986-1993 Volvo 240 Front Brake Caliper Replacement: 步骤 3 中的图像 2,2
    • Lift the brake caliper off the rotor and set it aside.
    • Place the caliper on some type of support so that you do not put too much strain on the brake hose.
  4. 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Caliper: 步骤 4 中的图像 1,2 1986-1993 Volvo 240 Front Brake Caliper Replacement, Front Brake Caliper: 步骤 4 中的图像 2,2
    • Use an open-end wrench to loosen the 11 mm fitting where the brake hose attaches to the caliper.
    • Brake fluid will come out of the loosened brake hose. You should keep a bucket or pan nearby to collect it.
    • Be careful when handling brake fluid, as it may strip paint and dissolve some plastics.
    • Detach the brake hose and remove the brake caliper.
    • When you install the new calipers you will need to bleed the brakes to remove any air from the brake fluid lines.
结论
另外一个人完成了本指南。
David Hodson
于04/13/10注册
150,455 声望
创作了127篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 6,253
