跳转到主内容
1986-1993 Volvo 240 Distributor Cap Replacement
你所需要的
  1. 1986-1993 Volvo 240 Distributor Cap Replacement, Distributor Cap: 步骤 1 中的图像 1,2 1986-1993 Volvo 240 Distributor Cap Replacement, Distributor Cap: 步骤 1 中的图像 2,2
    • The distributor cap is located next to the engine and has all of the spark plug wires connecting to it.
    • Pull straight up on the ignition coil wire in the center of the distributor cap to disconnect it.
  2. 1986-1993 Volvo 240 Distributor Cap Replacement: 步骤 2 中的图像 1,3 1986-1993 Volvo 240 Distributor Cap Replacement: 步骤 2 中的图像 2,3 1986-1993 Volvo 240 Distributor Cap Replacement: 步骤 2 中的图像 3,3
    • Connect the spark plug wires to the new distributor cap one at a time. Mixing up the order will result in the engine not firing properly or at all.
    • Pull straight up on the boot of the first spark plug wire to disconnect it from the distributor cap.
    • Be sure to pull on the boot and not the wire itself. Spark plug wires are quite fragile and may break easily.
  3. 1986-1993 Volvo 240 Distributor Cap Replacement: 步骤 3 中的图像 1,3 1986-1993 Volvo 240 Distributor Cap Replacement: 步骤 3 中的图像 2,3 1986-1993 Volvo 240 Distributor Cap Replacement: 步骤 3 中的图像 3,3
    • Install the spark plug wire onto the new distributor cap and make sure it is seated properly.
    • Continue to transfer each spark plug wire to the new distributor cap, maintaining the same arrangement of wires on the cap.
    • Once all of the spark plug wires have been installed on the new distributor cap, set the cap aside.
  4. 1986-1993 Volvo 240 Distributor Cap Replacement: 步骤 4 中的图像 1,2 1986-1993 Volvo 240 Distributor Cap Replacement: 步骤 4 中的图像 2,2
    • Use a flathead screwdriver to release the clip securing the distributor cap.
    • Only one side of the distributor cap has a spot for the clip to rest. The new cap must be installed in the same orientation.
    • Remove the old distributor cap.
    • When installing the new distributor cap, don't forget to reconnect the center ignition coil wire.
结论
2等其他人完成本指南。
David Hodson
于04/13/10注册
150,493 声望
创作了127篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 29
总计 6,560
