简介
A dirty or broken distributor cap may lead to a number of ignition problems in your Volvo 240. Consult your owner's manual for a regular interval to inspect your distributor cap for damage, excess wear, or carbon buildup.
你所需要的
Pull straight up on the ignition coil wire in the center of the distributor cap to disconnect it.
Install the spark plug wire onto the new distributor cap and make sure it is seated properly.
Continue to transfer each spark plug wire to the new distributor cap, maintaining the same arrangement of wires on the cap.
Once all of the spark plug wires have been installed on the new distributor cap, set the cap aside.
2等其他人完成本指南。
