跳转到主内容
1985-1988 Volvo 740 Tire Rotation
你所需要的
  1. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Jacking Front Wheels: 步骤 1 中的图像 1,1
    • Turn car off and remove keys from ignition.
    • Place car in park (automatic) or neutral (manual).
    • Engage parking brake.
  2. 1985-1988 Volvo 740 Tire Rotation: 步骤 2 中的图像 1,1
    • Use hydraulic jack on frame of car to raise car.
    • Place jack head underneath frame of car.
    • Only necessary to jack the car until the wheels are just off the ground.
  3. 1985-1988 Volvo 740 Tire Rotation: 步骤 3 中的图像 1,1
    • Place jack stand on frame of car and remove jack.
    • Do no work under car supported only by hydraulic jack, serious injury or death may occur.
  4. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Jacking Rear Wheels: 步骤 4 中的图像 1,1
  5. 1985-1988 Volvo 740 Tire Rotation: 步骤 5 中的图像 1,2 1985-1988 Volvo 740 Tire Rotation: 步骤 5 中的图像 2,2
    • Place jack head underneath frame couple (pictured).
  6. 1985-1988 Volvo 740 Tire Rotation: 步骤 6 中的图像 1,2 1985-1988 Volvo 740 Tire Rotation: 步骤 6 中的图像 2,2
    • Do not work under car supported only by hydraulic jack, serious injury or death may result.
  7. 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Tire Rotation: 步骤 7 中的图像 1,2 1985-1988 Volvo 740 Tire Rotation, 1985-1988 Volvo 740 Tire Rotation: 步骤 7 中的图像 2,2
    • Pry off the all four hub caps by placing a small flathead screwdriver between hubcap and rim pulling the screwdriver away from tire.
    • Pull hubcaps away from tires.
  8. 1985-1988 Volvo 740 Tire Rotation: 步骤 8 中的图像 1,1
    • Loosen each of the five lug nuts on all tires by turning them counter-clockwise with a 19mm wrench.
  9. 1985-1988 Volvo 740 Tire Rotation: 步骤 9 中的图像 1,1
    • Remove tires by pulling directly away from car exposing brake rotors.
  10. 1985-1988 Volvo 740 Tire Rotation: 步骤 10 中的图像 1,1
    • Swap tires according to diagram.
  11. 1985-1988 Volvo 740 Tire Rotation: 步骤 11 中的图像 1,1
    • Place tires on axels.
    • Hand tighten the lug nuts with narrow end of nut towards car.
    • Finish tightening the lug nuts with 19mm Torque Wrench to a torque of 63 lb*ft.
结论
团队
Cal Poly, Team 3-28, Regan Fall 2010 Cal Poly, Team 3-28, Regan Fall 2010 的会员
CPSU-REGAN-F10S3G28
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 2,603
