跳转到主内容
1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance
你所需要的
  1. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Preparing Car For Work: 步骤 1 中的图像 1,2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Preparing Car For Work: 步骤 1 中的图像 2,2
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 步骤 2 中的图像 1,2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 步骤 2 中的图像 2,2
    • Unlatch the two clasps, as outlined in the image.
    • Loosen the screw on the metal band, using a flathead screwdriver.
  3. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 步骤 3 中的图像 1,2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 步骤 3 中的图像 2,2
    • Disconnect the electronic sensor from the MAF.
    • Press on the 2 latches, pulling the cable away from the sensor.
  4. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 步骤 4 中的图像 1,2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 步骤 4 中的图像 2,2
    • Disconnect the rubber hose from the MAF.
    • Remove the MAF from the air filter housing.
  5. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 步骤 5 中的图像 1,1
    • Steps 4-6 are for cleaning only.
    • Spray the MAF cleaner along the direction of travel, shown by the arrow on top of the sensor.
    • (Mass Air Flow sensor Cleaner)
  6. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 步骤 6 中的图像 1,2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 步骤 6 中的图像 2,2
    • Clean the electronic coupling with an electronics cleaner.
  7. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 步骤 7 中的图像 1,2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 步骤 7 中的图像 2,2
    • Inject conducting lubricant into the MAF sensor electronic coupling.
  8. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 步骤 8 中的图像 1,3 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 步骤 8 中的图像 2,3 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 步骤 8 中的图像 3,3
    • Reattach the MAF to the air filter housing and the intake hose.
    • Tighten the screw on the metal band.
    • Latch the clasps on either side of the MAF.
  9. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: 步骤 9 中的图像 1,1
    • Reattach the electronic cable to the MAF.
结论
Isaac Nitschke
于10/11/10注册
67 声望
创作了5篇指南
团队
Cal Poly, Team 3-28, Regan Fall 2010 Cal Poly, Team 3-28, Regan Fall 2010 的会员
CPSU-REGAN-F10S3G28
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 49
总计 9,677
