跳转到主内容
1985-1988 Volvo 740 Brake Pads Replacement
你所需要的
  1. 1985-1988 Volvo 740 Brake Pads Replacement, 1985-1988 Volvo 740 Preparing Car For Work: 步骤 1 中的图像 1,2 1985-1988 Volvo 740 Brake Pads Replacement, 1985-1988 Volvo 740 Preparing Car For Work: 步骤 1 中的图像 2,2
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. 1985-1988 Volvo 740 Brake Pads Replacement, 1985-1988 Volvo 740 Jacking Rear Wheels: 步骤 2 中的图像 1,1
    • Turn car off and remove keys from ignition.
    • Place car in park (automatic) or neutral (manual).
    • Engage parking brake.
  3. 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 3 中的图像 1,2 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 3 中的图像 2,2
    • Use hydraulic jack on frame of car to raise car.
    • Place jack head underneath frame couple (pictured).
    • Only necessary to jack the car until the wheels are just off the ground.
  4. 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 4 中的图像 1,2 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 4 中的图像 2,2
    • Place jack stand on frame of car and remove jack.
    • Do not work under car supported only by hydraulic jack, serious injury or death may result.
  5. 1985-1988 Volvo 740 Brake Pads Replacement, Rear Brake Pads: 步骤 5 中的图像 1,2 1985-1988 Volvo 740 Brake Pads Replacement, Rear Brake Pads: 步骤 5 中的图像 2,2
    • Pry off the front hub caps by placing a small flathead screwdriver between hubcap and rim and pulling the screwdriver and hubcap away from tire.
  6. 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 6 中的图像 1,1
    • Loosen each of the five lug nuts on the rear left and rear right tires by turning them counter-clockwise with a 19mm socket wrench.
  7. 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 7 中的图像 1,1
    • Remove tires by pulling directly away from car exposing rear brake disks and calipers.
  8. 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 8 中的图像 1,1
    • Locate the two 17mm caliper guide bolts.
  9. 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 9 中的图像 1,1
    • Remove upper and lower guide bolts on rear left and rear right brake calipers with 17mm crescent wrench.
  10. 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 10 中的图像 1,1
    • Remove rear brake calipers from rotors.
  11. 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 11 中的图像 1,1
    • Locate the two rear brake pad retaining pins on each caliper.
  12. 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 12 中的图像 1,1
    • Remove brake pad retaining pins by punching them out with a 3mm allen key.
  13. 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 13 中的图像 1,1
    • Remove both rear brake pads by pulling them out of calipers.
  14. 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 14 中的图像 1,1
    • Insert two new brake pads into each caliper.
  15. 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 15 中的图像 1,1
    • Replace pin guide behind rear brake pads.
  16. 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 16 中的图像 1,2 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 16 中的图像 2,2
    • Verify that pins are inserted through caliper and brake pad holes and seated over the metal pin guides.
  17. 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 17 中的图像 1,1
    • Tap pins through both rear brake pads and caliper using a wrench.
  18. 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 18 中的图像 1,1
    • Replace rear calipers on rotors.
  19. 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 19 中的图像 1,3 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 19 中的图像 2,3 1985-1988 Volvo 740 Brake Pads Replacement: 步骤 19 中的图像 3,3
    • Finish by performing steps 1-5 in reverse order.
终点
另外一个人完成了本指南。
团队
Cal Poly, Team 3-28, Regan Fall 2010 Cal Poly, Team 3-28, Regan Fall 2010 的会员
CPSU-REGAN-F10S3G28
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 7,129
