当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
视频概述
这个步骤还没有翻译 帮忙翻译一下
There are a total of three phillips #3 bolts holding the handle to the door, two at the bottom, and a single one at the top
Your phillips #2 screwdriver will work fine here, but you could use a #3 if you want
For the top bolt there is a chrome trim covering it. You'll need to pry back gently - using a pick or small screwdriver so as to leave it undamaged
这个步骤还没有翻译 帮忙翻译一下
Looking down almost behind the window winder handle, you can see the trim panel has a bent-metal clip, the trim also acts as the locking-clip to hold the handle on
First push the trim panel outwards toward yourself
Then it slides away from the hub, towards the knob which you hold to rotate the handle
这个步骤还没有翻译 帮忙翻译一下
The interior door trim panel is held in place by a series of push-pins around the edge of the panel, you can pry them out using a plastic trim tool, or like I did here with a small prybar and rag
To avoid damaging the trim or the door, try to get the pry tool as close as possible to each clip then gently pry until it pops out
The trim panel separates below the top portion, so the lock-knob and window seal can remain in-place and undisturbed
Remember the trim panel is very-fragile and made of particle-wood, so handle it gently and place it out of harms way while you're working on the door
这个步骤还没有翻译 帮忙翻译一下
Peel back the vapour/moisture barrier plastic, mine was removed before, so the original glue was gone, I had some spots of double-sided tape holding it in
I just fed it through the partially-open window to hold it back, but if it's windy it might be annoying
We're trying to gain access to the door interior
这个步骤还没有翻译 帮忙翻译一下
My new part (1157251102) looked so full of promise with it's blue genuine parts label, and it's shiny metal it's manufacture date stamped 10/1987
However the installation was about to take a turn for the worse, I didn't realise at first, naively thinking a genuine part would just bolt-on
It turns out my new part didn't have threads tapped in the four bolt holes!
Can you believe it!?
So with a bit of cursing, I dragged out my tap and die set
If you get lucky you won't need to tap the holes on your replacement regulator
这个步骤还没有翻译 帮忙翻译一下
The arm that attaches to the bottom of the window uses a pin with clip and special washer
It's a bit fiddly since you can't see it easily, mostly you'll be working by feel, the clip slides into a groove machined into the tip of the pin
There is a rectangular plastic bushing that slides in the window-bottom track, it fits over the pin first
Then the pin and bushing go through the track
Then there is a plastic slightly-conical flat washer with a metal star-shaped washer that fits over that
Then at the very tip of the pin - facing into the door, there is a spring-steel clip
I used a pick and a flathead screwdriver and a pair of needlenose pliers and a bit of cursing to get it out and back in
NOTE: the window drops after you pull out the pin, since nothing is holding it up - I put a small prybar in place to hold it up, but you could also use a piece of wood or whatever
这个步骤还没有翻译 帮忙翻译一下
There are four bolts (circled in blue) holding the regulator to the door, they are all 10mm head bolts, but the top two are longer
I used a 10mm deep socket on a 1/4 inch ratchet, but any 10mm wrench, spanner, or socket should work
in the second picture you can see the gear-quadrant of my old regulator hanging down, it's supposed to be up engaged in the winder gear teeth
It was at this point that I realised I could not get the old regulator past the window vertical track...
Notice I'm using a short prybar to prop up the window now (since otherwise it drops down) you could use a piece of wood or some other tool as well
这个步骤还没有翻译 帮忙翻译一下
Since you can't get the regulator out past the window track, it has to be detached temporarily
It's held on by two 10mm bolts, which have fancy dimpled flat washers, and lock washers, I've circled them in green in the picture
Remove those two bolts, which should give you enough movement to push that window track forward off the window a bit, then into the door a bit deeper
At this point it should be possible to pull out the window regulator, angling it as you go to avoid jamming on things
这个步骤还没有翻译 帮忙翻译一下
As I mentioned in step 9, I was punished by the lack of threads in my new window regulator
So I broke out my tap and die set, and checked the bolt thread pitch, which was metric M6 x 1.0
I didn't notice until I'd already slipped my new part into the door... I actually pulled it back out of the door to tap the four holes
If your part also has a lack of threads in the holes, be sure to check it before you've put the clip through the pin, and reinstalled the track bolts etc
这个步骤还没有翻译 帮忙翻译一下
Install several of the regulator bolts (remember the top two are the long ones)
Don't tighten them yet
Grease up the window bottom track and bushings before assembling
The bushing clip is pretty hard to get on - enjoy that
After you're happy with the placement tighten the bolts
Then remember to put the vertical window track bolts back in too - they have the funny dimpled flat washers (be sure the window glass is in the track)
2等其他人完成本指南。
