跳转到主内容
1967-68 Mustang Kick Panel Speaker Replacement
你所需要的
  1. 1967-68 Mustang Kick Panel Speaker Replacement, Kick Panel Speaker: 步骤 1 中的图像 1,2 1967-68 Mustang Kick Panel Speaker Replacement, Kick Panel Speaker: 步骤 1 中的图像 2,2
    • Find the car battery under the hood.
    • On the battery locate the black negative battery terminal.
    • Next unscrew the knob on the disconnect.
    • Lastly move the negative lead away from the batter terminal.
    • Make sure not to cross the battery leads.
  2. 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 2 中的图像 1,1
    • Locate the kick panel speaker that needs to be replaced.
  3. 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 3 中的图像 1,1
    • Locate the two top screws as well as the two bottom screws for the speaker.
    • Check the kind of screws that were used to hold the speaker in place.
  4. 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 4 中的图像 1,3 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 4 中的图像 2,3 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 4 中的图像 3,3
    • You are now ready to start replacing the speaker.
    • A philips head screwdriver will be needed.
    • Do not use a socket in this situation because it may mess up the speaker guard.
    • Lastly make sure to remove the screw completely without stripping out the screw hole.
  5. 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 5 中的图像 1,3 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 5 中的图像 2,3 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 5 中的图像 3,3
    • The speaker guard and speaker are now ready to be removed.
    • Be careful when removing the speaker. Do not pull the wires tight.
  6. 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 6 中的图像 1,2 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 6 中的图像 2,2
    • Locate the wires on the back of the broken speaker.
    • Remove both the positive and negative wires.
  7. 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 7 中的图像 1,2 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 7 中的图像 2,2
    • Now locate the new speaker.
    • Slide the positive and negative wires onto the speaker terminals.
  8. 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 8 中的图像 1,3 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 8 中的图像 2,3 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 8 中的图像 3,3
    • Place the speaker back into the kick panel housing.
    • Line up the speaker holes with the existing holes in the kick panel.
    • Be careful not to pinch the speaker wires.
    • This would be a good time to replace the speaker wires if needed
  9. 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 9 中的图像 1,2 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 9 中的图像 2,2
    • Place the speaker guard back over the speaker.
    • Screw in all four screws
    • Do not over tighten the screws or the holes will strip out.
  10. 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 10 中的图像 1,2 1967-68 Mustang Kick Panel Speaker Replacement: 步骤 10 中的图像 2,2
    • Reconnect the negative battery terminal.
    • Screw the knob until it is snug.
结论
You have now replaced the speaker.
另外一个人完成了本指南。
John
于09/29/15注册
101 声望
撰写一个指南
团队
Cal Poly, Team 15-7, Green Fall 2015 Cal Poly, Team 15-7, Green Fall 2015 的会员
CPSU-GREEN-F15S15G7
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 24
总计 1,659
