跳转到主内容
1922 GE AOU Fan Power cord Replacement
你所需要的
  1. 1922 GE AOU Fan Power cord Replacement, Power cord: 步骤 1 中的图像 1,2 1922 GE AOU Fan Power cord Replacement, Power cord: 步骤 1 中的图像 2,2
    • Tip the fan to its side and remove the three size 8 screws using a 9/32 flat-head screwdriver.
    • The screws may be brittle from age, so be careful.
    • Take the bottom plate off the fan and set it aside.
  2. 1922 GE AOU Fan Power cord Replacement: 步骤 2 中的图像 1,1
    • Remove the three number 8 screws that hold the switch in place.
  3. 1922 GE AOU Fan Power cord Replacement: 步骤 3 中的图像 1,1
    • Remove the switch, carefully sliding the speed lever out of its slot.
    • Don't remove the switch too quickly or you can damage the head-wire.
  4. 1922 GE AOU Fan Power cord Replacement: 步骤 4 中的图像 1,1
    • Once the switch is free, unscrew the two knurled nuts holding the wires in place.
  5. 1922 GE AOU Fan Power cord Replacement: 步骤 5 中的图像 1,1
    • Turn the switch over and unscrew the nut securing the wire with the 5/16 crescent wrench.
  6. 1922 GE AOU Fan Power cord Replacement: 步骤 6 中的图像 1,1
    • Remove the switch and set it aside, then pull the wire through the grommet.
结论
另外一个人完成了本指南。
Elias Dorna
于06/08/16注册
125 声望
撰写一个指南
团队
Texas Tech, Team 3-5, Rauch SU 2016 Texas Tech, Team 3-5, Rauch SU 2016 的会员
TTU-RAUCH-SU16S3G5
2 名成员
创作了1篇指南
一条评论
Westinghouse table fan needs new cord (just bought). 18 gauge cord? Where to buy?
carol w - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 2,793
